Old 07-20-2006, 12:24   #1 (permalink)
Member: 232344
Thanks Meter: 7
Nokia 2300, Contact service
Nokia 2300 Contact service?any one have a proper solution.plz guide me thanx in adv.
Old 07-20-2006, 20:37   #2 (permalink)
hrkgloballinks's Avatar
Member: 129536
Thanks Meter: 9
I have a 2300 I have flashed with JAF,Twister but the problem,tripping off,persist
The Following 2 Users Say Thank You to hrkgloballinks For This Useful Post:
Old 07-20-2006, 20:39   #3 (permalink)
Member: 129536
Thanks Meter: 9
What baffles me is that the imei is not currupt
Old 07-20-2006, 21:22   #4 (permalink)
Member: 36906
change uem and all should be well.
Old 08-09-2008, 12:13   #5 (permalink)
Member: 722596
Thanks Meter: 2
please help me 2300 contact service
Old 08-09-2008, 12:18   #6 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
change cpu its 100000000000000000% solution its hardware
Old 08-09-2008, 12:32   #7 (permalink)
shaikh_zubin's Avatar
Member: 461699
Thanks Meter: 80
flash with latest pm file and reply
Old 08-09-2008, 13:32   #8 (permalink)
Member: 275451
Thanks Meter: 84
erase... n full flash with pm and ui...if not ok thn rehot flash...othewise rehot upp or change it
Old 08-09-2008, 18:53   #9 (permalink)
Member: 675717
Thanks Meter: 125
Yes Change UPP if any how not ok change UEM.
Old 09-12-2008, 08:11   #10 (permalink)
Winston rio hum's Avatar
Member: 631496
Sonork: 100.1581341
Thanks Meter: 112
same problem 2300b ( rm-5) contact service problem....
erase flash - full flash - write full pm -> i've done
with normal mode seem be ok
with battrey show contact service need solutions please
The Following User Says Thank You to Winston rio hum For This Useful Post:
Old 09-12-2008, 12:33   #11 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
all are good sugession.
Old 09-12-2008, 14:30   #12 (permalink)
dvsbbdd's Avatar
Member: 703284
Sonork: 0
Thanks Meter: 66
change uem ic 100%solution its hardware
The Following User Says Thank You to dvsbbdd For This Useful Post:
Old 09-12-2008, 18:44   #13 (permalink)
Member: 394340
Thanks Meter: 5
nokia 2300 after flash restart in 30 seciond aap ki bri mehar bani hogi
Old 09-12-2008, 20:15   #14 (permalink)
Member: 535623
Sonork: 100.1586332
Thanks Meter: 21
re-heat batt conector uper point. and also re-heat UEM by flux. not 100% solution.
you also try to flash update version..
thanks.......
The Following User Says Thank You to kathakunjo For This Useful Post:
Old 09-12-2008, 20:19   #15 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
bra..rehot cpu and uem then erase flash and flash again and re write good pm file may be u problem solved...........
nokia 6303c contact service help.............. RABIULSK MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 04-09-2010 21:18
nokia 6303c contact service help...... RABIULSK Universalbox 5 03-30-2010 11:31
Nokia 2300 Contact Service waqas317 Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-15-2010 08:30
Page generated in 0.21746 seconds with 10 queries
