02-22-2010, 09:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: india now oman
Member: 196876 Status: Offline Sonork: sabugsm Thanks Meter: 26 | hwk updation error |
The Following User Says Thank You to nafco2008 For This Useful Post: |
02-22-2010, 11:05 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Basti, I N D I A Age: 34
Member: 988641 Status: Offline Sonork: sanjay chaudhary Thanks Meter: 342 | bro, use ufs repair tool and click on all saras box tool and click on repair box option ........ all will ok................................. |
02-22-2010, 11:36 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: I /\/ D I /_\
Member: 580791 Status: Offline Sonork: 100.1623010 Thanks Meter: 103 | 1- format pc reinstall window...... 2-install hwksupport suite setup 2.0.9.0.... 3-conect internet conection & update u r box again with update client 4-install registry file 2.0.7.0. 5-install HWK suite setup v2.0.9.0 u r HWK instaling complet use new ver.. Enjoy............ .::AKTYAGI::. [email protected] |
02-22-2010, 17:50 | #6 (permalink) |
Freak Poster Join Date: Sep 2003 Location: tunisia Age: 46
Member: 39239 Status: Offline Thanks Meter: 97 | Box Auth Error 20 DO NOT, perform this process unless you have Box Auth Error 20, update client reports "use Update Firmware to authorise UFS !" or you are advised to do so. 1. Run the update client. 2. Select your language. 3. Click "Next". 4. Wait until the "Update UFS Firmware" button is enabled and then click it. 5. Select req.fbi file, you will need to get this file from the support area. 6. After a few seconds the process will complete and create a file called xxxxxx.req. (where xxxxxx is your UFS serial number) 7. Send this file to your UFS reseller. 8. When you receive xxxxxx.fbi from your UFS reseller, perform steps 1-4 above. 9. Select xxxxxx.fbi 10. After a few seconds your box will be authorised. Your UFS reseller is the only person who can help with this process, do not ask here in the forum, we will not generate xxxxxx.fbi files for you. NOTES:- 1. the xxxxxx.fbi file sent by your UFS reseller is one time use only. 2. once you have made the xxxxxx.req file, do not perform any other steps on the box, since this will cause the xxxxxx.fbi file to be out of sync. Odia. |
The Following User Says Thank You to riadhset For This Useful Post: |
hwk update error 2.7 bad update | arcade | HWK | 9 | 05-04-2008 08:23 |
hwk update error....... | wizz25 | HWK | 3 | 06-29-2006 15:40 |
Plz Help For Hwk Update Error Msg | .:LOCK UNLOCK:. | HWK | 0 | 05-31-2006 12:35 |
