08-20-2006, 13:56 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: In Internet Age: 40
Member: 116970 Status: Offline Thanks Meter: 3 | N91 when i remove battary cover mobile work ok but if i set cover mobile restart please i want way for solved it |
08-20-2006, 14:53 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | open your mobile then u will found hdd then remove it ========================================== [email protected] tc |
08-20-2006, 17:20 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | your phone battery is the problem. try replacing the battery. try checking battery connector pins. try checking your phone casing again. try checking battery lieing position before any application is applied . bestman |
08-21-2006, 04:14 | #4 (permalink) |
Freak Poster Join Date: May 2004 Location: QUIAPO,MANILA CITY PLAZA
Member: 65015 Status: Offline Thanks Meter: 7 | you got harddrive problem. harddrive is engage only when battery cover is put back in its place as a safety feature. you got to format the harddrive . |
08-25-2006, 02:44 | #9 (permalink) |
Freak Poster Join Date: May 2004 Location: Malaysia Age: 50
Member: 66197 Status: Offline Thanks Meter: 2 | N91 cannot access the HDD(hard disk) it cause by: -battery cover not in place -magnet missing from batt cover -HDD damage -corrupt data on HDD -poor interconnect between HDD and PWB |
08-25-2006, 02:50 | #10 (permalink) |
Member: 66197 Status: Offline Thanks Meter: 2 | Steps format N91 HDD press: 1.menu 2.tools 3.hard drive 4.options 5.tools 6.format Hard Disk *Quick format(1 minutes) *Full format(15 minutes):it'll ask to charge your phone when formatting |
08-26-2006, 10:57 | #12 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Dhaka, Bangladesh Age: 45
Member: 121753 Status: Offline Thanks Meter: 15 | N91 cannot access the HDD(hard disk) www.mobile-bd.com |
03-26-2007, 16:13 | #15 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
V3i when i keep using it works perfect but if i leave it it hang and freez???? | tsarkh | Motorola P2k | 1 | 10-20-2008 10:51 |
Sed Y690-working Ok-but When Charger And Usb Connect Set Power Off- | zonetrichur | Infinity-Box | 3 | 12-29-2007 15:16 |
i have problem mybe any wan can solved it if i open any soft for infinity ok but if i | gsm4libya | Infinity-Box | 2 | 05-01-2006 11:56 |
i have problem in K700 if i turn off ok but if i will power on not response | gsm4libya | Cruiser Suite | 0 | 04-28-2006 21:44 |
3100 flashed ok but not UI Settings!! | dynamic-gsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-29-2005 12:25 |
