08-23-2001, 07:36 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: GSMLAND
Member: 5764 Status: Offline Thanks Meter: 2 | I have seen hundreds of Nok3210 with the same problems! let's discuss it! |
08-23-2001, 16:28 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: INDIA
Member: 4223 Status: Offline Thanks Meter: 4 | Yes... This is Bcos of not proper Filtering of Rx Frequency. Check the Filter. U will b Happy Guy... Best of Luck... <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> |
08-23-2001, 17:19 | #3 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | thanks for reply. where is it? which filter? can you indicate exact location, name? Have you got such an experience, and have you ever tried this solution? does it help? could it be becouse of another hardware fault? |
08-23-2001, 18:57 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Some where around the world.
Member: 3845 Status: Offline Thanks Meter: 2 | HI <br />The filter look like chocolate chip(black colour).Or reflow the cobba ic.<br />Enjoys. :-) <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
08-23-2001, 22:13 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Viet Nam Age: 49
Member: 5487 Status: Offline Thanks Meter: 5 | Hi<br />If fillter is fault you can by pass it by sold direct two wire from pin 2 to pin 8 and pin 4 to pin 6. If it's not OK you must replace COBBA IC and re flash proggram.<br />rgds |
08-24-2001, 09:13 | #6 (permalink) |
Insane Poster Join Date: Jun 2001
Member: 5012 Status: Offline Thanks Meter: 0 | Hi Quang..<br />I think you right, nut re flashing nokia and then it not correctly network and no signal.<br />Can you mail me detail and we will discuus more about this problem!<br />regards!<br /> [email protected] <br /> <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> |
08-24-2001, 11:13 | #8 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | there are many filters on component side of 3210.Please indicate exactly, which one should be replaced. is it Epcos B4693 SAW RF filter; Fc = 1842.5MHz, Bandwidth 90MHz, OR Ceramic filter 13MHz +/- 0.09MHz, OR EPCOS; SAW filter 71MHz +/- 90kHz, OR, SAW filter; 232MHz +/- 0.5MHz, OR Murata; SAW filter 947.5MHZ +/-12.5MHz, used in Rx path after the LNA output, OR Epcos SAW filter B4677 range 890-915MHz (fc = 902.50), used in Tx path before the Power amplifier input, OR, Epcos B4109; SAW filter 1747.5MHZ +/- 37.5MHz, OR Epcos B4409; SAW filter 1747.5MHZ +/- 37.5MHz. |
08-24-2001, 15:38 | #9 (permalink) |
Freak Poster Join Date: Jul 2001
Member: 5364 Status: Offline Thanks Meter: 0 | Hi guys...3210 has a "sickness" with audio breaking up...i've done many by simply reflowing the COBBA only ...try it!!! <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> I only attempt filter IF reception bars r fluctuating & then causes audio prob. <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> |
08-24-2001, 16:19 | #10 (permalink) |
Member: 4223 Status: Offline Thanks Meter: 4 | Hello Sat... Sorry for make u in trouble. The filter is Located Below Right most Side if u r putting yr Board as that it's antenna contacts Stays UP side... Seems Like a Black Chocolate Chip or normal Crystal. But before doing this follow the Cells R Us and OTher Guys... Reflow the COBBA IC. (Don't try to change it... otherwise u'll b in trouble <img src="smile.gif" border="0"> ). B carefull and Best of Luck <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> |
08-24-2001, 19:59 | #11 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, That's the trouble, if you have faulty Cobba or accidently damage it by reflow you can't do anything about this phone. The value from inside ROM is used for the phone security routines and changing the chip will<br />require recalculating the default IMEI values - something could be done only in Nokia R&D department <img src="frown.gif" border="0"> . Some people say that Dejan can do this, but this is not confirmed yet by someone we can trust and the prices for log's are really high, not iconomical for repair ! The good old way is to change Cobba from different phone ( bad water fault or inside crack), but you have to transfer eeprom content from the dead phone to the repaired together with<br />Cobba. After that need to reset Full Factory in <br />WinTesla. If these two phones are different SW or PPM, need to update by Dejan 1.04. I don't know for 3210 - too much hassle. In our service center such phones go to the rubish bin <img src="smile.gif" border="0"> Best Regards |
08-25-2001, 07:06 | #13 (permalink) |
Member: 5764 Status: Offline Thanks Meter: 2 | I have reflowed COBBA from the opposite side of board. I was afraid to damage it by wrong reflow. Then I tested the phone, - nothing changed. I let it stay for a while, and then tried again, and it worked! Voice heard very clearly! Thanks all for help!!! By the way, how to reflow COBBA right? How much time should it stay under hot air gun? |
08-30-2001, 04:52 | #14 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | My friend, I guess that is a question of practice and experience. Let you gut feel dictate to you if enough reflow is enough. <img src="wink.gif" border="0"> |
Two SC with the same problem Help | celcel | Smart-Clip | 1 | 02-28-2009 10:12 |
Two E398 dead, both of them have the same problem!!!! Pls help me | ..::Thanh_gsm::.. | Motorola P2k | 4 | 10-09-2006 04:39 |
are the file of blazer is the same with other boxes? | palestine | Blazer | 0 | 02-19-2006 10:35 |
