Old 03-20-2003, 11:13   #1 (permalink)
DREAMGSM's Avatar
Member: 3377
IīM So tired, i canīt find solution for high power consumption!!!!
I measured the power consumption and was about 430-440 mAmp, then i changed the pa, reflow ccont, change ccont, try more paīs, change all bga, ... lot of components like capacitors , resistors... on microscope all seem right, no sulfate, no shorts, no break lines... iīm will turn crazy
the phone is a 3310 and a 3330... any idea?
Old 03-20-2003, 18:13   #2 (permalink)
Member: 14076
hi, try to change Display. i had one that i changed almost everything and nothing. Display was short circuitered.
Old 03-20-2003, 19:27   #3 (permalink)
Member: 1060
Thanks Meter: 9
Re: IīM So tired, i canīt find solution for high power consumption!!!!
HI,,
what capacitor you replaced ?
try to check all "big" capacitor which is connect to "VBATT"
and clean battery connector !
and aslo check VTX path !
or you can try give a resistor 22k or 68K from BSI to GND,
and use power supply give 4V to VB+ , and use wintesla to make TX outgoing power level at level 5, and see how is it current used, that 350~450 mA at level 5 is normal !
Willy
Old 03-28-2003, 11:13   #4 (permalink)
DREAMGSM's Avatar
Member: 3377
ok, thx willy for your help, i never replaced the big capaitors, only in 6210 for tipical repair hint, but never in others nokia, thanks again willy.
Old 04-07-2003, 10:59   #5 (permalink)
DREAMGSM's Avatar
Member: 3377
hi, i changed first capacitor from VBAT, now max is 400ma, normal more or less, but i have another question for you willy, if you can answer you will help me a lot, sometimes i find phones, 3310 and 8210 that consume 430-420 more or less, i changed pa and some solutions more as you said here days ago, but no result, there is courious thing as if you take the cables from external supply and donīt move them then the phone show 400-410 but if you move the cables up or down consume change quickly to 430-440 350... is no normal i supose and maybe indicates something that i canīt see and maybe so easy and simply, no cable problem because with good phone if you mave the cables consumption no change.
What do you thing about this?, strange problem, am i crazy? or what happen with ****ing Nokia phones, sometimes i want to crash nokia phones against the wall
Information allways will be appreciate mates thanks for your help,
sorry for english and best regards.
Where can I find solutions........... foufou34 Infinity-Box 5 04-04-2008 21:07
typhoon can find solution for 5300b network AYMAN SHAMAYLH Typhoon Dongle 7 02-11-2008 20:30
Where can i Find Manuals for nokia Reversing, installing leds and methods for Tuning DREAMGSM Nokia Hardware & Hardware Repair 1 07-20-2002 15:01
Where can i Find Manuals for nokia Reversing, installing leds and methods for Tuning DREAMGSM Off Topic Zone 0 07-20-2002 00:42
Where can i Find Manuals for nokia Reversing, installing leds and methods for Tuning DREAMGSM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-20-2002 00:39
Page generated in 0.26732 seconds with 8 queries
