01-05-2010, 22:14 | #1 (permalink) |
Registered User Join Date: Aug 2009
Member: 1087294 Status: Offline Thanks Meter: 252 | i think no member able to answer my question i want to know if a set comes in dead condition there is no shorting and when check on power supply meter needle does not show any work than how can we know what is the problem and which ic has problem if power switch is also ok. i return many of phones in this condition i rehot all ics but no result and after all i returned to customer. plz any member answer my question im very thankful to him |
01-05-2010, 22:22 | #2 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | Quote:
Rashid Ahmed Nadeem | |
The Following 2 Users Say Thank You to r a nadeem For This Useful Post: |
01-06-2010, 07:54 | #4 (permalink) |
Junior Member Join Date: Aug 2008 Location: india (assam) Age: 41
Member: 846585 Status: Offline Sonork: jaisen Thanks Meter: 2 | 1)just check p.f.o continuity . 2)resolder battry connector, 3)check +ve line of battry connector,from other any same model, 4)just make a jumper fom +ve track of battry connector to the piont wich is founf from another set. i solves many of sets with d same prosedure. |
The Following User Says Thank You to jaisen For This Useful Post: |
01-06-2010, 08:32 | #5 (permalink) |
No Life Poster Join Date: Jul 2008 Location: pakistan
Member: 821450 Status: Offline Sonork: khalil_lush Thanks Meter: 269 | try these steps 1. check shortage ( if shortage then check resist r220 , ringer ic , light coil , uem ) 2. check charging ( if charge ok then problem is in ur power switch ) 3. check in software with jaf if check is ok then try to flash 4. if check is not ok with jaf then read jaf message what the problem is in ur set uem or upp or ram hope u will solve ur problems [email protected] |
The Following User Says Thank You to AUN_KHALIL For This Useful Post: |
help to update and able to use my UFS 3 | abdo37 | HWK | 0 | 11-25-2008 01:18 |
Why no one answer my questions? | yusukii | KULANKENDI Server | 0 | 03-26-2007 10:33 |
Is anybody capable of answering my question? | bbbbbb | Nokia Hardware & Hardware Repair | 0 | 01-12-2004 11:07 |
