Old 04-20-2009, 21:19   #1 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
Ichal_spy Hardware Analisys here
I have Training Centre here In Indonesia...
ill upload some analysis of hardware problem that we success finishing here....
br
Borneoflasher Training and Service Centre Indonesia.....
ichal_spy
The Following 23 Users Say Thank You to ichal_spy For This Useful Post:
Old 04-20-2009, 21:30   #2 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
KEypad and Display Light failure anaylisi and solution
i receive nokia 6300 no light at display and keypad....
Steps :
1. check vbat at L2304 = normal
2. check Pwm pin from tahvo ic at j2316= normal 1.8v
3. check vled out from Light ic = normal
Summary Light Ic dan tahvo Ic is normal
Next Step :
chek out put from n2401 at test point j2428 there is no voltage... normally... its must be 18volt
Analysis : Failure at ic n2401
Then i check the way at n2401... i find that there is between L2403 to N2401 is not conneted....
solusition : Jumper L2403 to pin 4 at N2401
result :
Display ligh is normal .. But keypad light still not normal
B]Next Step:[/B]
cek output at r2408 = 18v
Check out put at r2418 = no voltage...nomally it must be 15volt
COLOR="Blue"]Analysis :[/COLOR] Failure at v2401
solusi : because i dont have this componenet (v2401)
i make a trik with make a jumper from r2408 to r2419
Result... :
Keypad light is normal ... and Display Light is normal too
ichal_spy
sorry because the pict in Indonesian....
The Following 18 Users Say Thank You to ichal_spy For This Useful Post:
Old 04-20-2009, 21:35   #3 (permalink)
Member: 883190
Sonork: 1587513:khalifa
Thanks Meter: 87
special man in hardware. we need some one like you here in rwanda
The Following 3 Users Say Thank You to kamanzi For This Useful Post:
Old 04-21-2009, 11:55   #4 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 147
superb post with good explaination , we want people like you in this forum
hats off to you
The Following 3 Users Say Thank You to linekbp For This Useful Post:
Old 05-05-2009, 23:39   #5 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
6680 BT Error
I found Nokia 6680 error at Bluetooth... (Operation failed)
Measurement :
Check Vio at c6035 = 1.8v normal
Check Vregout At C6036 = 0 (It should be 2.8v)
Analisis....
Vregout Regulator (N6031) is damaged....
Step.... Make Jumper between Vaux (C1470) 2.8v to Vregout C6036
Result......
ichal_spy
Borneoflsher Trainig Centre
Indonesia
The Following 14 Users Say Thank You to ichal_spy For This Useful Post:
Old 05-05-2009, 23:56   #6 (permalink)
Member: 883190
Thanks Meter: 87
good work ichal u're istimewa man
The Following User Says Thank You to kamanzi For This Useful Post:
Old 05-06-2009, 06:30   #7 (permalink)
Member: 684635
Thanks Meter: 12
istimewa...kekekeke...
great job..keep posting brother...
Old 05-06-2009, 06:35   #8 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,540
really good work my dear fren,,,u are the best,,,,and hard worker,,,,,,,,,,
regards
gsmshare
Old 05-06-2009, 06:49   #9 (permalink)
Uwo_jj's Avatar
Member: 619882
Sonork: 777.33200.768
Thanks Meter: 398
hello ichal, how much should I pay for the practice directly to the place you in Indonesian? i m from LA hollywood! heheheheh
Old 05-06-2009, 06:55   #10 (permalink)
willydewi's Avatar
Member: 331835
Thanks Meter: 64
good job bro ichal
The Following User Says Thank You to willydewi For This Useful Post:
Old 05-06-2009, 06:57   #11 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
Case Nokia 6630 Signal Problem....
Object :
Step :
Searching manual on phone at setting, Network...... Manually...
REsult : No Operator Found
So in this case the problem is at RX Part or Receiver
Measurement step....
1. Check Rx i/q di J7508, J7509, J7510, J7511..... Not Good datas... so the problem is around RF Ic not rap problem.. cause the data come from rf ic to Rap..
2. Check Control Vco at pin out cp at rf ic... Result is Noise.. so the problem is at CP Out line (Control VCO).. at BB5 phone the problem is always damaged at capasiror 2n2.. so i change it...
after change.. i check again and its not noise anymore....
after that i search manually the network again.. result.. all operator is found...
but after selec an operator its cant acces.. its show NO Accest at display...
so problem now is at TX (Transmitter).. RX Problem is solved....
Next step....
Check Control VCO for TX at cp out line at Vinku result.... No line...
its mean VCO for Vinku not working....
Next step....
Check VCO Coltage at c7555... No Voltage... its must be 2.8v
Check vreg2 at C7548 No Voltage too its must be 2.8v too cause its be at same way with vco voltage...
Check way between c7555 and cc7548 result the way is OK...
Summary.....
Damaged is at VCO Voltage.. its not be 2.8volt.....
Solution....
Find another voltage... example Vreg1 with same value....
Make jumper betweenVreg1 (C7543) yo Vreg2 (C7548)...
after make jumper I check control VCO is ok... and not noise....
Turn on the phone.. and the result is....
Best Regards...
ichal_spy
Borneoflasher Training Centre
Indonesia
The Following 12 Users Say Thank You to ichal_spy For This Useful Post:
Old 05-06-2009, 07:10   #12 (permalink)
Crazy Poster
Member: 1006476
Thanks Meter: 22
Go..go mr.ichal...
Waiting the next anylisys..
The Following 2 Users Say Thank You to G.M.S For This Useful Post:
Old 05-06-2009, 07:42   #13 (permalink)
Member: 459470
Thanks Meter: 17
good job ichal...we always support you ......
The Following User Says Thank You to azi_kewl For This Useful Post:
Old 05-08-2009, 18:13   #14 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
3100 No Signal analisis....
Step :
Searching Manual no operator found...
so the problem is at RX part (Receiver)
step....
Check Rx i/q at J611,J612,J613 dan J614.. thya
the data is like this..
so.. RF part is ok,,,,
and we dont have to check RF Voltage, RF Bus, RF CLock etc... its must be OK cause rx i/q is ok.....
Summary....
the problem is on PM or UEM
next step.... Write good pm ... result... Same..
next step
reball UEM...
[IMG][/IMG]
br
The Following 6 Users Say Thank You to ichal_spy For This Useful Post:
Old 05-08-2009, 18:32   #15 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
here the result....
The Following 5 Users Say Thank You to ichal_spy For This Useful Post:
Any Mobile Hardware Solution Here. mizancoxr Hardware Repair by brands 11 11-22-2007 07:30
all siemens hardware solutions here ::.::SOUFIZ GSM::.:: Siemens Hardware Repair Area 21 05-08-2007 19:41
nokia n73 hardware soulation here aleenasager Nokia Hardware & Hardware Repair 1 10-14-2006 01:57
All Siemens E-Gold Software and Hardware solution here .::Unlocker.:: E-Gold Based Phones 2 02-08-2006 13:14
Page generated in 0.43267 seconds with 8 queries
