Old 11-24-2008, 08:33   #1 (permalink)
Registered User
Member: 726313
Thanks Meter: 2
if you have a problem in nokia hardware post here i will help you in 24 ours
post all problem of your nokia unit im willing to help
within 2 ours or 24 or less ours i will help you in easy but tested
tips by me
try me now or evryday
Old 11-24-2008, 08:38   #2 (permalink)
Member: 540344
Sonork: **** u GSMman
Thanks Meter: 110
oh men great work.
are you from nokia company that have much knowledge in nokia hardware repair?
Old 11-24-2008, 08:41   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
i have 2600c complete flashing with different version using ufs+hwk and jaf
show local mode after flash but not charging and nothing
to power on and i try to remove local mode solution
base on tricks and i use power supply 3.6/.7 still remain problem
Old 11-24-2008, 08:48   #4 (permalink)
Member: 540344
Thanks Meter: 110
i have 1100 here men wat is the problem when if u put simcard it doesnt power on but with out simcard yes it will power on and can call 112.
tried to flash all the flashfile in the support of jaf but after flash just the same problem.
The Following User Says Thank You to kulafuk For This Useful Post:
Old 11-24-2008, 08:49   #5 (permalink)
jerieves's Avatar
Member: 239484
Thanks Meter: 14
his from nokla company.. anyway why not try him?
2 ours or 2 hours? LOL
Old 11-24-2008, 09:13   #6 (permalink)
Member: 540344
Thanks Meter: 110
@THREAD STARTER
pls help me regarding my problem in 1100....this unit is almost 4 yrs now with me.
now i have seen your thread maybe it helps me with this
Old 11-24-2008, 09:15   #7 (permalink)
persianuser's Avatar
Member: 516318
Thanks Meter: 27
7610 with four flashes!!
the soft knows four adresses
ASIC ID: 1081
WD2 BT2
w3_2nd.fia
w3_amd.fia
84F5633E66A80243CE478A81C1B1
Configuration Info (9F):
Number of Flashes: 4
00000000: Samsung, 00EC 2250 0000 0121, 10
02000000: Samsung, 00EC 2250 0000 0121, 10
04000000: Samsung, 00EC 2250 0000 0121, 10
06000000: Samsung, 00EC 2250 0000 0121, 10
ExtBUSC: 0200 0000 502D 4081 ABF2 0000 2402 0000
Erase[24.69 MB]...
erasing region [00000000 to 0000FFFF]
erasing region [00010000 to 00FFFFFF]
erasing region [02000000 to 0287FFFF]
%%%%%%%% ERROR ERASING:
Failed at address 02600000
Old 11-24-2008, 09:16   #8 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 451
hi bro can you give me solution
nokia 6280 camera not worke
when i check him see this message:
operation echoui.
thank's .
lahdache
Old 11-24-2008, 09:20   #9 (permalink)
Registered User
Member: 726313
Thanks Meter: 2
sir try to replace the 3 filter above helga
its a ordinary solution iknow coz many times i encounter same case like
your problem i do the filterrs changes
Old 11-24-2008, 09:21   #10 (permalink)
Registered User
Member: 726313
Thanks Meter: 2
replace bsi diod
what is bsi?
bsi is a black diod contains regular volts or supply
you see a bsi diod in back of battery terminal
Old 11-24-2008, 09:22   #11 (permalink)
Member: 540344
Thanks Meter: 110
but that 3 filters you are saying is for signal.
how come it affect the power fault?
FYI
1100 is the unit, is there an helga in 1100... show me where i can find helga in 1100 pls i dont know where it is
Old 11-24-2008, 09:22   #12 (permalink)
Registered User
Member: 726313
Thanks Meter: 2
operation echoui.
thank's .
lahdache
replace flex sir many times tested
when you go to cam the unit have a problem like hang or etc
its coz a flex problem
Old 11-24-2008, 09:24   #13 (permalink)
Registered User
Member: 726313
Thanks Meter: 2
ASIC ID: 1081
WD2 BT2
w3_2nd.fia
w3_amd.fia
Erase[24.69 MB]...
please insert a full details of problem unit
like
unit is dead or what?
but as i can see
no flash ic detected your unit put a new f12 ic
and try to flash the unit
Old 11-24-2008, 09:27   #14 (permalink)
billal1050's Avatar
Member: 860925
Sonork: Now I'M Malaysia
Thanks Meter: 294
...::: Nokia E70 Insert Memory Card Problem :::...
Hi To All................
My Nokia E70 Insert Memory Card Problem.....
I Allready Changed MemoryCard Ic & More Than 3 Memorycard.....
But Same Problem ....Pls Help Me All Nokia Master...................
Pls Help..........................................
Old 11-24-2008, 09:34   #15 (permalink)
Registered User
Member: 726313
Thanks Meter: 2
just replace
c563 capacitor
and your problem i done
if you are problem to mp4 mp5 post here harrispiang Game Consoles & Mp3/4 , HD players 115 10-18-2013 12:44
If you have a problem with your hwk (No more upgrade logs) post here !! Supplier4unlock HWK 8 06-21-2008 06:05
Anyone having prob / fix "no flashloader /id for this hardware post here in link Rezn Universalbox 0 05-30-2008 13:00
Success in Nokia flashing. Post here all logs and Models name! GSMtricks Multi-Box 2 12-16-2007 17:43
Page generated in 0.45522 seconds with 8 queries
