12-23-2009, 16:48 | #16 (permalink) |
Freak Poster Join Date: Aug 2003 Location: india Age: 51
Member: 36991 Status: Offline Thanks Meter: 61 | repair method to“Power Down on Incoming/Outgoing Call the problem is caused by the ui sheild assembly shorting with the earpeice track on board, check the picture and put a adhesive tape. problem will be solved |
The Following 4 Users Say Thank You to rushi For This Useful Post: |
12-23-2009, 16:58 | #17 (permalink) |
Member: 36991 Status: Offline Thanks Meter: 61 | N86 8MP phone hangs when typing SMS REASON Some N86 8MP phones UI may get jammed when typing SMS message. In some phones this failure happens very often and it is easy to reproduce. Problem is caused by IO-expander (N2850) that is located to engine board. This component has two manufacturers and components manufactured by Toshiba may cause the problem. CHECK THE IMAGE |
06-14-2010, 10:28 | #20 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Error Age: 40
Member: 553840 Status: Offline Thanks Meter: 122 | Quote:
thx alot dear its 100% working soloution...... keep it up... Regard,s | |
06-14-2010, 10:33 | #21 (permalink) | |
No Life Poster Join Date: Jul 2007
Member: 551619 Status: Offline Thanks Meter: 136 | Quote:
Can you help me to Solve this Problem..??? http://forum.gsmhosting.com/vbb/f148...rking-1021718/ | |
06-27-2010, 18:23 | #22 (permalink) | |
Junior Member Join Date: Mar 2007
Member: 462791 Status: Offline Thanks Meter: 0 | Quote:
This is the same problem that I had please explain ... how I can flash the phone with E71_blank_504KB_pmm_10.fpsx thanx | |
12-27-2010, 19:51 | #23 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1258543 Status: Offline Sonork: [email protected] Thanks Meter: 0 | sir where can i download this file[Flash E6_blank_504KB_pmm_10.fpsx file]. thanx |
12-28-2010, 21:21 | #24 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | hello guys , have e66 phone got a problem : phone doesnt start up little vibrate and after a while the phone is switched of flashed with latest rm343_500.21.009 AR but not fixed also tried the above but no use any help whould appriceated |
motorola software update locked my motokrzr k1 | martindale024 | Motorola P2k | 0 | 05-01-2008 02:20 |
