Old 09-30-2003, 05:14   #1 (permalink)
Member: 39092
irDA can't use on NOKIA, but SAMSUNG OK, WHY???
I have a IrDA, it can use for Samsung C100, V200, S300... but can not use for NOKIA 6100, 6610, 72xx...
Please help me!!!
Old 09-30-2003, 10:00   #2 (permalink)
Registered User
Moosani's Avatar
Member: 15866
Thanks Meter: 192
check ur irda device
Old 09-30-2003, 16:34   #3 (permalink)
Member: 39092
Thanks!!!
Thanks! But can you tell me how to check my irDA device?
Old 10-05-2003, 13:22   #4 (permalink)
ASHIF's Avatar
Member: 8353
Sonork: 113276
Thanks Meter: 335
check ur infrared setting in Network option of control panel...
Old 10-05-2003, 19:45   #5 (permalink)
WEXIM's Avatar
Member: 13164
put the speed of your infrared device to 57 kbps and it'll work (it's in network adapter or device manager-infrared adapter)
Old 10-06-2003, 06:02   #6 (permalink)
Member: 39092
Thanks, but when I do it, SAMSUNG phone can use irDA in this speed?
Old 10-06-2003, 11:06   #7 (permalink)
WEXIM's Avatar
Member: 13164
of course it can use 57 kpbs
the problem you have is that the phone disconnects every 2-3-4 seconds ?
Old 10-06-2003, 14:53   #8 (permalink)
Member: 39092
yes, it's disconnects in 5 second! I don't know how to repair!
Old 10-06-2003, 16:26   #9 (permalink)
WEXIM's Avatar
Member: 13164
I already told you what to do
if you don't give more details, I cannot help you
Old 10-07-2003, 05:40   #10 (permalink)
Member: 39092
Thanks! Here is my problem:
I have an irDA, it can use with SAMSUNG phone, and 8210, 8250, but can't not use with 6610, 6100, 72xx... When i connect with these phone, my computer know the phone, but after 4-5 minute, is broken link. I don't know what speed tranfer is best? defaut is 4000000, and 1ms. Is it correct?
Thanks for your help!
Old 10-07-2003, 10:41   #11 (permalink)
WEXIM's Avatar
Member: 13164
you give the same details as you gave previously
what OS ?
what kind of adapter (brand, where bought) ?
disconection is every 4-5 minutes or every 4-5s?
what chipset type you have?
Old 10-07-2003, 12:51   #12 (permalink)
Member: 39092
I used WinXP, I used Red Bridge SigmaTel irDA, i haven't got driver of it! It'll disconnect in 4-5 s.
Old 10-07-2003, 12:52   #13 (permalink)
WEXIM's Avatar
Member: 13164
As a workaround, you may change the default setting of the
"Transceiver type" in Device Manager by doing the following steps :
1. Windows XP : go to "Control Panel"- "System"- "Hardware"-"Device Manager"-"Infrared Device"
Windows 98/ME : go to "Control Panel" - "Network" - "Configuration" - "SigmaTel US-IrDA Dongle"
2. Double click "SigmaTel USB-IrDA dongle".
3. Select "Advanced".
4. Change the default "Infrared Transceiver Type" to "Vishay TFD". (the default type is "Infineon <default>"
5. Set the "Speed Enable" to "400000".
6. Click "OK" to exit.
7. If you still encounter problem during transmission, you may need to go to step (5) to set the "Speed Enable" to lower speed, i.e., "115200" or "57600".
Old 10-07-2003, 14:31   #14 (permalink)
Member: 39092
I see in tab advance these value:
SigmaTel 4000
SigmaTel 4012 (default)
Vishay TFD
Which one will I choose?
and Speed?
Old 10-07-2003, 16:52   #15 (permalink)
WEXIM's Avatar
Member: 13164
I'm very surprised of your question.
read in my previous message
report nk6220c can't use on flashing bus [SOLVED] suffa Cyclonebox 4 10-16-2009 05:22
F2400 Flash Ok But can't power on why? denard HWK 2 12-08-2007 21:56
Urgent please help on nokia 2310 software ok but no power on with battery mobilecitycbk Nokia Hardware & Hardware Repair 1 11-15-2007 13:09
help zv10 no outgoing on 1sim but incoming ok CHAPRAN QUALCOMM Models (3G) 0 11-21-2006 10:30
what cable to use on Nokia 1100b rps13sh UFS2 + UFS3-Tornadoflasher 6 02-02-2005 11:42
Page generated in 0.21331 seconds with 9 queries
