Old 09-04-2007, 12:43   #1 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
JAF Guide Step by step II (only for new guys)
2. Service Operations
Let's continue this guide...
The service operation options are used to modify files or manage security options that can be found in the phone. We have 15 options that we will describe carefully.
You must select the option/s that do you want to perform and then press Service button. Let's describe the functions
1)Read PM: PM or Permanent memory it's a memory inside the phone with low capacity(I think it's around 1MB. And it contains security and setup options. With this funcion we will get a copy of the content inside the phone that can be used in case of Software problems. You must put the address that you want to read of the PM(0 to 255)
2)Write PM:It's the opposite action and will write a saved file. It's often used to repair phones with problems of Software or Security-IMEI
3)Erase PM: It's a limit solution to repair a phone with the Software or Security problems. We will erase first the PM and then write a new one. It's also used to repair imei when changing UEM to write a new PM file for the new IMEI
4)Self Tests: Using this function we can test the hardware parts of any Nokia phone and check if there is any Hardware problem if any of the tests fails.
5)Disp Test: also known as Display Test, we are going to try this function in order to see how is working the screen, if there are dead pixels or damaged screen-leds
6)Upload TUN: upload TUN (tunning) file for CDMA phones
7)Factory Settings:Through this option we will be able to "reset" the phone to the primary state. Data will be lost and any security info will be replace by default info.
8)Prod. Manager: This means Product Manager, it can be used to reset total time call and other warranty details
9)File Sys Format: Used to remove any user data contained in the phone, this function it's used on Symbian phones to repair oversize files uploaded(reboot at Nokia animation hands)
10)User Code Edit: This is a useful function. Through this function you will be able to read/write any user code.
11)Upload PP: PP or Product Profile, used in the old DCT4 phones, may be needed after changing the PPM for decustomization, games and apps can not work
12)Download PP: Just a "backup" or a file to upload to any other phone of the same kind
13)ADC Read: Reads ADC values from phone like charging current, voltage, battery current voltage etc.. Very useful in detecting power problems
14)Fun Explorer: It's a way to see the flash memory of the phone for the user. It will work better using Pc suite as new phones developed can hang the application
15)Warranty reset: Repair warranty imei from original imei, reset repair date to none, also reset life timer to zero (carefull with life timer, it may cause contact service so saving pm is recommended before)
3. Unlock Options
Unlock function and the different options
1)Init simlock-> This function will reset the lock of the phone to the first situation. It will become unlocked to any networks when you will press the Unlock Button.
2)Write SIM file
3)Code Calculator-> JAF software has an application inside the software to calculate the unlocking codes of any DCT4 handset. You must follow carefully the instructions and in a few seconds you will have the unlock code
4)Read Codes->This function was enabled some time ago in the INF button but it made a bit slow this function. If you want to give the unlock code to your *******r just select this function and then press the Unlock button
5)Autolock NET&IMSI->Autolock options, IMSI and NET - When set, the phone will lock itself on first inserted simcard using IMSI or NET code.
6)Lock to network->Write here the five characters to block the phone to the network that you consider. Be careful or it will be blocked to all networks
4. Operation Log
This is a normal operation log where you must see your PKEY number but you never must write in forums.
You can check that the % of the pkey has not reach 0%. You can always stablish this number to 100% going to Pkey tab and press Update Pkey
And the next info just remind us the version of firmware inside the box and the Pkey as well as the Nokia Loaders Address
You must have the loaders up to date. A high percent of flashing problems is due to the loaders version.
Operations in DCT4 Tab
This is an extra option added to the DCT4 guide but it works in the same way in the BB5 tab.
We have thir**** options in ths part of the window.
INF button it's used to read the phone information, like IMEI, software version inside the phone, kind of the phone, MCU,PPM, UEM, LCD versions...If you are an advanced user you can learn for the information provided here in order to repair possible problems in a phone
JAF version 1.97 beta9
Detected PKEY: 80000000
Card life counter: 98.44%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.A7
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version:
(Date of IMEI warranty)
(Type of Model)
(c)NMP
HW version:Phone name
PCI version:
UEM version:
UPP version:
RFIC version:
DSP version:
LCD version:
PPM version:
23-07-2004
R
L
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
ESN plain: 03308818555
ESN hex: 21 86 8F 7B
PDC: 4E 54 54 4A 50 12 34 56
ESNX plain: 00000000
ESNX hex: 00 00 00
Master Code: 2453516132
SPC: 000000
XTKSL: 000000
Phone type: , Software version: , Language Pack:
User code: 12345
Searching for saved ini...
CHK button. It will boot the phone in flash mode, reads flash ids, load flash loaders and make FAID authentication. This is usefull in detecting flash chip problems, upp, uem problems etc, cables check
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: 2000C088 -> SEC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 2000C088 -> SEC Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 2000C088 -> SEC Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 2000C088 -> SEC Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Done!
Phone Restarted...
Flash, Service and (Un)Lock buttons must be pressed when we will chose any of the functions of the three first steps of our guide.
You must select firstly the function and when it's ready press one of this three buttons.
Erase Fls- Use this function just when you will have learn well what it's used for. This function will leave the phone EMPTY. If you are not careful the phone will not have IMEI and you won't be able to make calls. Check that you have saved PM file and try first with any and useless old phone.
Load Java- As it's own name tell us, this function it's used to load JAVA Games&Apps to our phone.
Repair BT- The use of this function it's nowadays nearly useless. At the beginning of the first bluetooth phones JAF software wasn't perfect and the address of the BT on the phones could be damaged. Using this function you will be able to repair any software issue. You can avoid problems just by press Skip BT in the flashing options.
MMC Rst- This is an extra function to remove any password in a MMC. All the information of the MMC will be lost.
Read fls- By using this function you will be able to read any section of a flash file in any phone. You can try it, it's free...
Make INI- It's used to create an INI file if it doesn't exist before with the files used for the flashing porpouse
Prod Dir- This will select main folder for flash files instalation for ex c:\program files\nokia\phoenix\products\
IMEI Tool- It's for changing IMEI on ani Nokia phones.
Phone Mode- I personally has used this function a couple of times to check how is working the communication between cable and phone. You can change the mode to any state.
Communication Mode- You can perform some operations by USB Dku Cable. Here you can select what interface do you prefer.
The Following User Says Thank You to meo786pk For This Useful Post:
Old 09-04-2007, 12:46   #2 (permalink)
ab media's Avatar
Member: 440017
Thanks Meter: 28
great job man...nice tutorial...thanks....
Old 09-04-2007, 15:08   #3 (permalink)
Member: 248245
Thanks Meter: 85
thanks meo786pk for nice sharing.
Old 09-04-2007, 15:48   #4 (permalink)
Miftahudin's Avatar
Member: 115242
Sonork: 100.1581364
Thanks Meter: 1,638
Not only for basic users also very good and useful guide for some advance user’s
Best regards,
Old 09-23-2007, 08:57   #5 (permalink)
Member: 531339
good job man.. a lot of help 4 me as a beginer,,,
Old 10-31-2007, 23:58   #6 (permalink)
Member: 621057
well done i`m a junior member and i find this very interesting how and i get step one?
Old 11-01-2007, 00:19   #7 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
thanks meo786pk great job man !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-01-2007, 03:23   #8 (permalink)
Member: 296067
Thanks Meter: 50
thk,i just want buy 1,great sharing
Old 11-01-2007, 03:48   #9 (permalink)
shoaibk7's Avatar
Member: 145000
Thanks Meter: 20
great work nice sharing
keep it up
shoaib
Old 11-01-2007, 06:58   #10 (permalink)
Member: 575719
Thanks Meter: 19
pleasemy help /////////////////////////////////////////////////////////////////////////
Old 11-01-2007, 07:11   #11 (permalink)
shaikh_zubin's Avatar
Member: 461699
Thanks Meter: 80
i want installation guide.
Old 11-01-2007, 13:44   #12 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
U get all inf about jaf from this file .........
read it carefully u know all function of jaf........
thanks to big brthr raskal...........
Old 11-02-2007, 07:15   #13 (permalink)
Member: 401873
Thanks Meter: 8
thanks,
it is very usefull information.
can you pls give me brief information about pm. how to read and write. what is addressing (0-255). what is network pm and how to write it, how to address it.
Old 05-16-2008, 08:35   #14 (permalink)
Member: 430450
Thanks Meter: 7
Thank bro nice for us
Old 05-16-2008, 12:39   #15 (permalink)
vicky kumar's Avatar
Member: 737188
Thanks Meter: 37
goooooooooooooooooooddddddddddddddddddddddd maaaaaannnnnnnnnnnnnnn.......................
Guide: How to Activate SETOOL Step by Step shahzaadbutt SETool2 66 06-15-2023 11:12
[GUIDE] Step by Step Guide for Upgrading P3400 and P3400i ROM + FAQs ..::Mobile Smoker::.. HTC & PDA WM( With Touchscreen) 7 04-01-2012 16:41
JAF Guide Step by step II (only for new guys) meo786pk Nokia Hardware & Hardware Repair 4 08-03-2011 13:41
Anyone can post step by step guide for flashing cdma's!! tarun79 Nokia CDMA 0 03-21-2006 10:46
Page generated in 0.28009 seconds with 10 queries
