Old 06-16-2008, 11:30   #1 (permalink)
Member: 68978
2630 keys
hi guys . i´ve a problem with water damaged 2630 , keys not working , any solution for this ??
Old 06-16-2008, 11:35   #2 (permalink)
Member: 718473
Thanks Meter: 8
same problem fom my set pls help arzent..............
Old 06-20-2008, 07:15   #3 (permalink)
Member: 527340
Thanks Meter: 7
i change keypad ic near cpu but keys not work track also come i check mettar some differant volue 'pls' help anyone
Old 06-20-2008, 07:31   #4 (permalink)
Member: 457144
chang top key pad .................................................. ....
Old 06-22-2008, 08:58   #5 (permalink)
Member: 392076
i have same problem and one beep sound continue in speaker i change keypad ic and keypad but same problem
Old 06-24-2008, 08:57   #6 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
" bro u can do it easily but if u r sure that keypad is fixed accurately then u hav to rehot upp & nothing else problem will be solved provided inside to out prints i.e from upp to key prints & also inside& outside tracks of keypad board print r ok, no other option & no other solution, thanx"
2630 key pad problem shami61 Nokia Hardware & Hardware Repair 8 08-19-2010 10:11
2630 key problem laddimobile Nokia Hardware & Hardware Repair 8 04-27-2009 22:59
2630 key problem laddimobile Nokia Hardware & Hardware Repair 1 12-26-2008 18:21
2630 keys asonimi Nokia Hardware & Hardware Repair 3 09-27-2008 13:54
my nokia 2630 keys not working. Teepat Nokia Hardware & Hardware Repair 0 07-16-2008 21:17
Page generated in 0.16392 seconds with 9 queries
