Old 01-10-2009, 04:27   #1 (permalink)
Member: 775682
Thanks Meter: 14
Keypad Error for Nokia 6120c
Hello..
I have problem with keypad nokia 6120c.
Button Menu, *, 0, #,left joystick and outside camera button doesn't work at all.
Please share with the solution.
Thanks
Abu
The Following 2 Users Say Thank You to abu nawaz For This Useful Post:
Old 01-10-2009, 05:11   #2 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 144
change keypad ic first that is the solution................
The Following User Says Thank You to shinod For This Useful Post:
Old 01-11-2009, 02:24   #3 (permalink)
Member: 775682
Thanks Meter: 14
Hi Shinod,
If I already change but still same, any jumper trick without change the ICs?
Thank you
Old 01-11-2009, 02:31   #4 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 185
if you change the Ic and still same error : means other solution should be ,i think bad track near to PILE going to Ic keypad is cuting ? but i don't have any picture anyone one have schematique Thank's
Old 01-11-2009, 06:53   #5 (permalink)
Member: 775682
Thanks Meter: 14
Hi Tetuan
Thanks, anybody...dear sir or ma'am, please share the picture if you have.
Could you please help me......
Old 01-11-2009, 07:06   #6 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
Just Change The Keypad Ic............
Old 02-23-2009, 13:27   #7 (permalink)
Member: 782954
Sonork: sajidchakwal
Thanks Meter: 14
where is key pad ic?
Old 02-23-2009, 13:30   #8 (permalink)
Member: 782954
Thanks Meter: 14
sir where is 6120 key pad ic?
Old 02-23-2009, 15:43   #9 (permalink)
Member: 974368
Sonork: red com
Thanks Meter: 2
the keypad ic is somewhre around the simcard connertor.usualy nokia patern is all the same... the ic have 24 dots on it..
Old 03-04-2009, 09:04   #10 (permalink)
Member: 782954
Thanks Meter: 14
6120c 3,6,9,# work as up down rite left . i change ic , make jumper also but prob is same. any idea?
Old 04-09-2009, 09:02   #11 (permalink)
Member: 34379
Thanks Meter: 75
try this
http://rapidshare.com/files/21918540...c_key.JPG.html
also ceck keypad track
Old 04-09-2009, 09:55   #12 (permalink)
hamzaa's Avatar
Member: 84694
Thanks Meter: 9
Keypad ic on 6120 is near lcd connector.
Old 04-09-2009, 10:46   #13 (permalink)
shahidsattar's Avatar
Member: 388454
Thanks Meter: 1,100
check it and reply
[IMG][/IMG]
The Following 9 Users Say Thank You to shahidsattar For This Useful Post:
Old 04-09-2009, 11:03   #14 (permalink)
Member: 34379
Thanks Meter: 75
I have track brocken from keypad connector to keypad ic. key 7,8,9 doesent work
The Following User Says Thank You to valiu For This Useful Post:
Old 04-09-2009, 13:00   #15 (permalink)
Member: 388454
Thanks Meter: 1,100
also check this
[IMG][/IMG]
http://i43.tinypic.com/16h7m6s.jpg
The Following 12 Users Say Thank You to shahidsattar For This Useful Post:
diagram for nokia 6120c deann Nokia Hardware & Hardware Repair 4 04-11-2013 02:19
Smart Movie For Nokia 6120c kumar_pvj Nokia Multimedia 1 07-05-2008 12:33
FTD for Nokia 6120c mga_soft Nokia Base Band 5 ( BB-5 ) 4 03-04-2008 21:09
need pinout for nokia 6120C-1 fethi Infinity-Box 2 02-09-2008 22:58
HOW HAVE SERVICE PDF FOR NOKIA 6120c i need pinouts from rap and flash chips please. oOXTCOo Nokia Hardware & Hardware Repair 3 11-18-2007 14:01
Page generated in 0.82307 seconds with 8 queries
