Old 09-26-2006, 13:41   #1 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
Keypad Ic For Nokia 6070 Working
Need To Know That Is There Ne Difference Between The Keypad Ic Which We Use In 6600,3220 Etc
In 6070
Because As I Have Changed The Ic With New One In 6070 It Is Not Working
Also Made Ui Settings Then Also Same Problem Keypad Not Working
Need Help Thanks
The Following 2 Users Say Thank You to chiragp For This Useful Post:
Old 09-26-2006, 14:19   #2 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
try changing the volume switch
The Following User Says Thank You to linekbp For This Useful Post:
Old 09-26-2006, 14:23   #3 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
No Bro U Dont Get Me The Handset Is Box Pack
But While Removing Sim Card With Pin He Or She Has Broken The Keypad Ic So I Have Changed With Fresh 6600,3220 Etc Keypad Ic
But It Is Not Working
I Think That May Be Nokia Has Changed The Comtability Of Ic
The New Ic May Have Some Changes From The Old One
Need Help
Old 09-26-2006, 17:37   #4 (permalink)
Member: 326228
Thanks Meter: 31
no brother key pad ic,s are same try to change another goodluck
Old 09-27-2006, 08:14   #5 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
Thanks For Reply Bro
I Will Check With Another
Old 05-14-2007, 17:13   #6 (permalink)
Member: 291019
Thanks Meter: 17
hay all i have changed 3 ic from 6600 in 6070 i dont knw whats tha problem but now my navigation key left and right not working plz any one know show help me
The Following User Says Thank You to mobileworld1 For This Useful Post:
Old 08-29-2007, 16:53   #7 (permalink)
Member: 301521
Thanks Meter: 12
hey
same problem
any solution for right key?
changed volume switch
keypad ic (5 times)
and keypad also
but just right key not works
without volume switches not working too
Old 11-28-2007, 03:40   #8 (permalink)
Member: 109294
Thanks Meter: 22
6070 keypad ic
Somebody who knows,
What's the right keypad IC used in this phone, somebody says 8310 IC works, but that one doesn't have left and right keys...
Please answer!
Tnanx
The Following User Says Thank You to gsmgsa For This Useful Post:
Old 11-28-2007, 04:53   #9 (permalink)
kanwal's Avatar
Member: 496736
Thanks Meter: 17
why u not go for jumpering of key pad
Old 12-10-2007, 11:55   #10 (permalink)
Member: 301521
Thanks Meter: 12
hy
i hv solved my problem with rehotting upp
Old 12-10-2007, 12:10   #11 (permalink)
Member: 109294
Thanks Meter: 22
6070 Cpu
lucky you!
Me - changed keypad driver - result: same problem: up down and soft keys left and right don't work
- rehot Upp didn't work either - result - same pb as above
- took off UPP - reballed it, result: same pb as above.
Now I'm gonna have to change UPP cause I guess that's the pb.
Regards
Old 12-10-2007, 15:24   #12 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
In 6070
Need Help Thanks
GETTING THE RIGHT KEYPAD IC IS NOT ENOUGH, BUT YOU ALSO NEED THE EXPERTISE TO FIX IT IN PLACE CORRECTLY FOR GOOD RESULT. TRY AGAIN AND BE MORE CAREFUL. GOOD LUCK.
The Following 2 Users Say Thank You to ABUU YUUNUS For This Useful Post:
Old 12-10-2007, 16:19   #13 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
i want to share my knowledge about keypad ics that the ic in nokia 1110 can b used in these models!{1110i,1112,6030,3230,3230,7260,6020,6021,6 600,7610,etc}......
But bb5 have different type of keypad ics....{6630,6680,6681,3250,5200,5300,6233,6234,62 80,6288,6230i etc}
..::MrFone::..
The Following 4 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 12-10-2007, 19:13   #14 (permalink)
bocahklaten's Avatar
Member: 295100
Thanks Meter: 212
..::MrFone::..
good info friend....
The Following User Says Thank You to bocahklaten For This Useful Post:
Old 12-18-2007, 11:52   #15 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
hi bro 3230 mmc not warking ple help
keypad ic for w580...... azmi_2112 Sony Ericsson Hardware Repair 5 09-21-2012 05:44
i-Pmart BX Series RJ48 10 Pin Cable Compatible For Nokia 6070 For MT Box IPMART ipmart WebShop 0 04-14-2009 04:40
where is the keypad IC in nokia 3230? deep_6111 WD2 & APE (Symbian Phones) 1 12-27-2007 10:26
keypad ic for new Nokia series thecult Wanted Products 3 11-15-2007 08:42
need keypad IC for 8310 tedjo13 Hardware Repair Item Wanted 0 10-09-2003 20:23
Page generated in 0.24119 seconds with 11 queries
