Old 12-20-2007, 12:19   #16 (permalink)
Member: 171953
Thanks Meter: 3
Originally Posted by kerim92 View Post
same problem
any solution for right key?
changed volume switch
keypad ic (5 times)
and keypad also
but just right key not works
without volume switches not working too
Tray to replace ic keypad 2 line or used jumper option.
Old 12-21-2007, 20:09   #17 (permalink)
Cheater
Member: 212401
Thanks Meter: 2
hi bro 3230 mmc not warking ple help
Old 12-21-2007, 20:10   #18 (permalink)
Cheater
Member: 212401
Thanks Meter: 2
good info friend....
Old 12-21-2007, 20:35   #19 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,513
Iam sorry to say but,i think your problem is solved when you have fixed that ic perfectly.
Old 02-02-2008, 07:58   #20 (permalink)
Member: 513486
Thanks Meter: 3
try to change keypad ic or
The Following User Says Thank You to shareej For This Useful Post:
Old 02-14-2008, 07:30   #21 (permalink)
Member: 303799
Sonork: inside outside
Thanks Meter: 59
me too same problem here.only 0 and 8 are working.i tried replacing keypad ic more than 5 times.but same problem.any idea mates?i also rehot upp.still same problem.
Old 06-26-2008, 07:09   #22 (permalink)
Member: 116294
Thanks Meter: 17
very good knowledge...
Old 06-30-2008, 14:34   #23 (permalink)
Member: 199996
Thanks Meter: 41
I have a phone 6070 keypad not working.
It may many solution but i found the problem with power on button was short.
I changed the power on metal button the phone is ok.
try it
thanks
Old 06-30-2008, 15:13   #24 (permalink)
ShadowmanX's Avatar
Member: 71526
Thanks Meter: 47
same problem
keypad ic (5 times)
and keypad also
hi,
Try to change/short Z2401 filter. 6070 pcb differ from 3220 This filter is under shield . Don't forget say thank's
The Following User Says Thank You to ShadowmanX For This Useful Post:
Old 07-11-2008, 13:12   #25 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
nice share good info thanxx
Old 09-26-2008, 08:34   #26 (permalink)
Member: 833601
Exclamation
hi
my nokia 7610 has keypad problem it's not warking
pl helppppppppppp me
Old 10-23-2008, 15:11   #27 (permalink)
Member: 833601
my nokia 6020 has keypad ic problem pl help me??????????????
Old 10-23-2008, 16:49   #28 (permalink)
jkniji's Avatar
Member: 643992
Sonork: 100.1625367
Thanks Meter: 179
Brother change the key paid pcb its carbon will not proper. try this and send report.
Old 10-23-2008, 17:15   #29 (permalink)
Member: 883039
Hi,pls i need solution 4 nokia1200 keypad,*,0,#.pls if anybody no either d jumper or anyother remedy
Old 10-23-2008, 18:18   #30 (permalink)
Member: 859094
Sonork: MTM303
Thanks Meter: 16
try to jumpering make 6070
keypad ic for w580...... azmi_2112 Sony Ericsson Hardware Repair 5 09-21-2012 05:44
i-Pmart BX Series RJ48 10 Pin Cable Compatible For Nokia 6070 For MT Box IPMART ipmart WebShop 0 04-14-2009 04:40
where is the keypad IC in nokia 3230? deep_6111 WD2 & APE (Symbian Phones) 1 12-27-2007 09:26
keypad ic for new Nokia series thecult Wanted Products 3 11-15-2007 07:42
need keypad IC for 8310 tedjo13 Hardware Repair Item Wanted 0 10-09-2003 20:23
Page generated in 0.42839 seconds with 9 queries
