12-11-2008, 08:51 | #1 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 607792 Status: Offline Thanks Meter: 316 | Kindly post it here all kinds of Shorted Units.. check shorting in 5200 and 5300..... 1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 4..remove this ic ..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery.... 5..remove this coil mark in (5)..if u want to check the light ic is short.... 6..also check the memory card driver ic n3200 it also got +b it can be check by only removing this ic..... 7..at end remove retu and tahvo ic... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... 100% actual learning |
The Following User Says Thank You to borgydeleon For This Useful Post: |
12-11-2008, 08:54 | #2 (permalink) |
Member: 607792 Status: Offline Thanks Meter: 316 | check shorting in 5310.. 1..remove this coil mark in (1)...if u want to check is light ic is short,..... 2..remove this coil mark in (2)..if u want to check ringer ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check audio amplifier voltage maker ic n2101 is short because bluetooth ic also got +b volt from battery.... 4..remove this rf ic mark in (4)..if u want to check the shorting is remove because rf ic got +b from batery. it can be check only by removing this ic 5..remove this ic mark in (5)..if u want to check the shorting is removed..this ic also got +b it can be check only by removing this ic . 6..also check the blue tooth ic because it also got +b from batery it can be check only by removing this ic 7..at end remove avilma and betty ic... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... 100% actual learning |
The Following 2 Users Say Thank You to borgydeleon For This Useful Post: |
12-11-2008, 08:59 | #4 (permalink) |
Member: 607792 Status: Offline Thanks Meter: 316 | check shoring in nokia 6111... 1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check the light ic is short.... 3..remove this coil mark in (3)..if u want to check flash light driver ic is short because flash light driver ic also got +b volt from battery.... 4..remove this boot ic mark in (4)..if u want to check the shorting is made by boot ic .....it is often damage in water damage set ....replace ith new one if it cause shorting...... 5..remove this n2371 mark in (5)..if u want to check the v.camdig maker ic which make v camdig for camera ...it also got +b from batery..... 6.. check the n2370r ic ...it make vcorea suplyy for cpu ... it also got +b it can be check by only removing this ic..... 7..remove ringer ic mark in (7) to check shorting is gone or not... 8..remove bluetooth ic to check shoting is gone mark in (8)...... 9..remove uem to check shorting...... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... 100% actual learning |
12-11-2008, 09:01 | #5 (permalink) |
Member: 607792 Status: Offline Thanks Meter: 316 | check shorting in 6300... 1..alisin ang coil nasa picture (1)...kung ang pf nya ay short ,..... 2..alisin ang coil nasa picture (2)..kung gusto mo malaman kung rf ic ay short kc ang rf ic ay may supply +b volt sa battery.... 3..alisin ang coil nasa picture (3)..kung gusto mo malaman kung blutooth ic ay short kc ang bluetooth ic may suply din +b volt sa battery.... 4..alisin ang coil nasa picture (4)..kung gusto mo malaman kung v.camdig maker ic ..ang v.camdig maker ic ay may supply +b sa batery.... 5. alisin ang coil nasa picture (5)..kung light ic ang short.... 6..i check mo din ang memory card driver ic n3200 may suply din +b nache check lang pag inalis ang ic na yan ..... 7..at sa huli eto alisin mo >>>>>> retu and tahvo ic... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... 100% actual learning |
12-11-2008, 09:03 | #6 (permalink) |
Member: 607792 Status: Offline Thanks Meter: 316 | check shorting in nokia n-70... 1..remove this z7500 mark in (1) if u want to check the shoting of pf of gsm and wcdma ....if remove the coil and ur shoting is gone then tere is shoting in ur pf of gsm or wcdma ........ 2..remove this coil mark in l7503 (2)...if u want to check the shoting of rf ic for gsm hinku and rf ic for wcdma vinku.... by removing this coil if ur shoting is gone then there is shoting in ur rf ic whether it is hinku or vinku.... 3..remove this coil mark in (3)..if u want to check the shoring cause flash light driver ic n1471 ....because this ic got +b from batery.... 4..remove this coil mark in (4)..if u want to check smps ic n4200.. ..this ic make v corea for omap ic and rap remove cil to check shoting is gone or not..... 5..remove this ic n4201 ape regulator mark in (5)..if u want to check the shoting is cause by this remove it to check shoting is gone or not.... 6..remove light ic mark in (6) ... to check the shoting cause by light ic or not.... 7..remove n1472 ic mark in (7) ...it is vcamdig maker ic which make v.cam when front camera is activated ......remove this to check shoting because this ic got +b from batery...... 8..remove ic n1470 and n7505 ic mark in (8,9)... it is c camdig maker ic which make v.cam or front camera ....remove these ic to check shoting .....because it got +b from batery..... 9..remove bluetooth module mark in (10)... tocheck shoting ...because it got +b from batery..... 10..at end remove retu and tahvo ic to check shoting....... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... 100% actual learning |
12-11-2008, 09:06 | #7 (permalink) |
Member: 607792 Status: Offline Thanks Meter: 316 | check shorting in nokia 6630.... 1..1..remove this coil z7500 mark in (1) if u want to check the shoting of pf of gsm and wcdma ....if remove the coil and ur shoting is gone then tere is shoting in ur pf of gsm or wcdma ........ 2..remove this coil mark in l7503 (2)...if u want to check the shoting of rf ic for gsm hinku and rf ic for wcdma vinku.... by removing this coil if ur shoting is gone then there is shoting in ur rf ic whether it is hinku or vinku.... 3..remove this coil mark in (3)..if u want to check smps ic n4200.. ..this ic make v corea for omap ic and rap remove cil to check shoting is gone or not..... 4..remove light ic mark in (4) ... to check the shoting cause by light ic or not.... 5..remove n1470 ic mark in (7) ...it is vcamdig maker ic which make v.cam when front camera is activated ......remove this to check shoting because this ic got +b from batery...... 6..remove n6031 ic mark in (6)... it is vreg maker ic for bluetooth module .....remove it and check shoting if ur shoting is then replace it.. this ic got +b from batery.... 7..at end remove retu and tahvo ic to check shoting is gone or not.... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... 100% actual learning |
03-15-2009, 15:49 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | oh oh guys waiting for update or ur late to copy paste of my posts from this thread... http://forum.gsmhosting.com/vbb/showthread.php?t=556022 wbr, digitized |
All Kinds of Repair Exe Please post it Here | borgydeleon | Nokia Hardware & Hardware Repair | 7 | 03-12-2009 02:36 |
GSMkey - can it unlock all versions of NEC e313, e616 and e616V? | laxxe | NEC | 0 | 12-15-2004 01:18 |
GSMkey - can it unlock all versions of LG U8120? | laxxe | LG | 0 | 12-15-2004 01:17 |
