10-15-2011, 09:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | at last i solved 3110c mmc problem problem not solved then i try this because it is tested by me many times but problem still so after that i try with this jumper with above soloution after that my problem solved 100% if any one have more information about this topic just replay here i m here to answer |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
10-15-2011, 09:15 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2009 Location: CH,BD,HK
Member: 1179761 Status: Offline Sonork: 100.1602000 Thanks Meter: 1,834 | Hey, What about your image? image not clear. What about you red jumper? Follow 2nd image and your image, my green jumper wherever end your mmc socket jumper connection are same. Check now and reply Anyway follow this http://forum.gsmhosting.com/vbb/f148...-easy-1055641/ |
The Following 2 Users Say Thank You to nerobdms™ For This Useful Post: |
10-15-2011, 09:28 | #3 (permalink) |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | yes my dear sir after ur post green jumper problem not solved then i make my red jumper also here ur green jumper. that means green jumper is also tested by me but sometimes if it is not work then simply i do green jumper and my red jumper and phone works 100%.i test 2 phone with my soloution.but i test more than 10 phone with ur soloution |
10-15-2011, 09:42 | #5 (permalink) | |
Member: 1179761 Status: Offline Sonork: 100.1602000 Thanks Meter: 1,834 | Quote:
But i did not find different anything from your image If you better success between from me, just i have specially welcome to you Go ahead | |
The Following User Says Thank You to nerobdms™ For This Useful Post: |
10-15-2011, 10:00 | #6 (permalink) | |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
so can not pass the voltage.so i just make this jumper and success. i m not best from u.because i follow u all times.pls read my whole post.hope u will be clr all | |
10-15-2011, 11:22 | #9 (permalink) | |
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote: ok my dear sir may be u don't get time to read my whole post . just answer here 1.where i say these two post are not tested???????? 2.can u tell me all solution works 100%???? 3.what do u mean about this sentence( problem not solved then i try this because it is tested by me many times)????? 4.translate it?? (so after that i try with this jumper with above solution) i know u r my senior so i m w8 for ur meaningful replay also thanks to u for commenting my post . | |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
