Old 12-20-2009, 18:29   #1 (permalink)
Member: 691144
Thanks Meter: 1,324
which lcd will be fit on 2330c
The Following User Says Thank You to izhanji For This Useful Post:
Old 12-20-2009, 22:14   #2 (permalink)
Member: 603622
Thanks Meter: 15
2330ñ is the same as 5000 or 3110c.Check it by connecing.
The Following User Says Thank You to Chevron For This Useful Post:
Old 12-20-2009, 23:18   #3 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
try 2630 lcd i hope its same with 2330...........
The Following User Says Thank You to chohansahib For This Useful Post:
Old 12-21-2009, 01:19   #4 (permalink)
Member: 603999
Thanks Meter: 5
try to equation 3110c sir....
Old 01-11-2010, 17:34   #5 (permalink)
Member: 573868
2330 lcd
same as 3110c fits and works perfectly
Old 02-15-2010, 15:10   #6 (permalink)
Member: 275689
Thanks Meter: 64
2630 lcd will not fit into 2330c, i just tried it now. which other lcds fit into 2330c, other than 3110c?
Old 02-15-2010, 15:15   #7 (permalink)
mobileunlockers's Avatar
Member: 396778
Thanks Meter: 155
there all same 3109/3110/3100C​/3500C/2680
Old 02-15-2010, 15:24   #8 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
dear u can use 3110 lcd easily in 2330 tested cut the side lockes of 3110 lcd and fit that .TC
Old 02-16-2010, 13:34   #9 (permalink)
Member: 275689
Thanks Meter: 64
Is there any sort of software available, which tells that which LCDs are compatible with other phones. Like a similiar software to the ones they have for Nokia FBUS or samsung cable, which tells which FBUS cable can go into which other phone
Old 02-16-2010, 13:58   #10 (permalink)
Member: 1236127
Sonork: 00923453696650
Thanks Meter: 18
Try This Bro Ur Problem Will B Solve
http://www.4shared.com/file/22317879...nder_v200.html
After Activation Which model will be support? vistasamir SETool2 3 03-29-2010 19:47
pls tell me which cable will be used to unlock samsung t639 urgent shahi UST Pro II 1 10-26-2008 15:47
Which Cable will be Use for J700 Unlock satzone UST Pro II 1 07-09-2008 16:21
Page generated in 0.18239 seconds with 10 queries
