04-24-2007, 06:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Learn Here How To Service Network Problems HOW TO FIND WHICH SECTION IS FAULT Tx (or) Rx? Testing Rx section use manual search for Testing Rx section, after searching Rx section good condition means it shows network list like Airtel, hutch, (or) any other network list in your area, If Rx section bad condition after searching it shows NO NETWORK FOUND 1, after searching it shows network list means Rx section is ok. 2, after searching it shows NO NETWORK FOUND means Rx section is fault. Testing Tx section Use manual search for testing Tx section, after searching it shows network list, then you can choose your simcard network, if Tx section is good condition it shows HOME NETWORK SELECTED, if Tx section is fault it shows NO ACCESS. 1, after selecting network it shows HOME NETWORK SELECTED means Tx section is ok. 2, after selected network it shows NO ACCESS means Tx section is fault. Information of Rx section components and ics nokia dct-3 tech 1, antenna switch 2, RF IC ( Hagar ic ) 3, AUDIO IC ( cobba ic) 4, crystal oscillator 5, filters 6, VCO (voltage control oscillator) Information of Tx section components and ics nokia dct-3 tech 1, PF IC (PA IC) Information of Rx section components and ics nokia dct-4 tech 1, antenna switch 2, filters 3, RF IC 4, crystal oscillator 5, VCO (voltage control oscillator) 6, UEM IC Information of Tx section components and ics nokia dct-4 tech 1, PF IC (PA IC) HOW TO SERVICE Rx SECTION FAULT ? Solution for Rx section no network found fault nokia dct-3 technolagy 1,clean the pcb well and Rehot (if not ok follow one by one solutions) 1, give antenna switch jumper 2, Rehot the RF IC 3, Rehot the AUDIO IC 4, Reball the RF IC 5, change the RF IC 6, change the AUDIO IC 7, change the crystal oscillator Solution for Rx section NO NETWORK FOUND fault nokia dct-4 technology 1, clean the pcb well and Rehot (if not ok follow one by one solutions) 2, give antenna switch jumper 3, Reheat the RF IC 4, change the crystal oscillator 5, Reball the RF IC 6, change the RF IC 7, Change filters HOW TO SERVICE Tx SECTION FAULT ? Solution for Tx section NO ACCESS fault nokia dct-3 technolagy 1, Change the PF IC Solution for Tx section NO ACCESS fault nokia dct-4 technolagy 1, Change the PF IC SOLUTION FOR OTHER NETWORK FUALT Solution for low network coverage, all models 1, give jumper from antenna contact to cabinet antenna 2, change the antenna switch Solution for dct-3 technology When switch on the mobile it shows full network after few seconds its goas down 1, flash - Rebuild ime - UI settings (if not ok follow 2nd solution) 2, check the track from battery +ve point to PA IC, if track is ok then change the good PF IC. Solution for dct-4 technology When switch on the mobile it shows full network after few seconds its goas down 1, write good pm file (if not ok follow 2nd solution) 2, change the PF IC, if still the problem same check the PF power track to battery +ve point |
The Following 4 Users Say Thank You to sree krishna For This Useful Post: |
04-25-2007, 10:23 | #4 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Ryt Here...Phil Age: 39
Member: 463891 Status: Offline Thanks Meter: 2 | even though we are very far geographicaly....its nice knowing mates that share thier knowledge to the world.... Thanks mate very helpful hint.... PULAX |
04-26-2007, 16:54 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | What abt this network fault...Tdy customer bought Ngage phone when i search manually its showing only one operator (Other 3 operators are missing)why is that? All network work under 900/1800..What will be the problem? |
04-26-2007, 20:44 | #7 (permalink) | |
Freak Poster Join Date: Jun 2004 Age: 35
Member: 68833 Status: Offline Thanks Meter: 68 | Quote:
bro , they must be the anttena swicht problem... | |
04-27-2007, 01:59 | #9 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 366974 Status: Offline Thanks Meter: 31 | your problem solution like at this site... http://forum.gsmhosting.com/vbb/show...380227&page=21 how you can do that?? |
05-04-2007, 13:04 | #14 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Hi Sree Krishna, What may be the solution of NOKIA 3310 of DCT-3 as NO NETWORK COVERAGE after manual search? Is there any difference between NO NETWORK FOUND and NO NETWORK COVERAGE? Your early and thoughtful solution will be appretiated. Thanks in advance, amit123 |
Learn Here How To Flash B3410 - B5722 - I400 | tsarkh | Samsung Flashers, Software, Firmware. | 4 | 10-26-2010 13:45 |
how to fix network problem in kg 275 | yasminato | Infinity-Box | 3 | 06-21-2008 01:13 |
>>> how to solve Network Problem <<< | Faisal_Computer | Infinity-Box | 9 | 03-31-2008 10:05 |
Learn Here How To Service Network Problems only for new guys | meo786pk | Nokia Hardware & Hardware Repair | 6 | 12-11-2007 06:10 |
how to resolve network problem after dowgrade T630 , R7A to R4A | leroi | Sony Ericsson | 1 | 02-28-2006 17:48 |
