Lumai 510 screen light off on call I have Lumia 510 .. when I make call screen light goes off .. when call ends screen light again comes .. I flashed it with its product code file with atf , but still same problem .. need expert help... |
1 Attachment(s) Quote:
nokia lumia 510 display light the first check lcd connector clean of corrosion check working voltage ic lights U2403 in L2401 and C2408 check her out lcm pwm C2427 ..... lcm backlight enabled at R2410 ISET light at R2407 and R2401 lcd backlight enabled in see the picture below dont forget to click thank |
nokia lumia 510 display light halp |
Plz help lumia 510 display light |
any solution of lumia 510 blank display. windows key light is working but no display |
remove screen paper ur problem solved100% |
There in no screen protevtor problem is blank display i have changed lcd but no display. but phone is working fine. pls help. |
u just remove light sensor |
change light sensor or stick with 2 side glue. |
it's censor light or censor problem try it |
nokia lumia 510 key light ok but no lcd light |
Just change d touch screen prob solved 100% |
i think its a sensor problem.................. |
l have a nokia lumia 510 ,when the display light goes off to standyby the phone immediately restart,,,how can l solve this plizzzz |
