Old 04-21-2013, 04:11   #1 (permalink)
Member: 772651
Thanks Meter: 1,515
Lumai 510 screen light off on call
I have Lumia 510 .. when I make call screen light goes off .. when call ends screen light again comes .. I flashed it with its product code file with atf , but still same problem .. need expert help...
The Following User Says Thank You to ajit bs For This Useful Post:
Old 04-26-2013, 13:15   #2 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 5,937
nokia lumia 510 display light
the first check lcd connector clean of corrosion
check working voltage ic lights U2403 in L2401 and C2408
check her out lcm pwm C2427 ..... lcm backlight enabled at R2410
ISET light at R2407 and R2401 lcd backlight enabled in
see the picture below
dont forget to click thank
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 05-03-2013, 05:27   #3 (permalink)
Member: 1909131
Thanks Meter: 3
nokia lumia 510 display light halp
Old 09-01-2013, 08:49   #4 (permalink)
Member: 1181857
Plz help lumia 510 display light
Old 11-12-2013, 08:15   #5 (permalink)
Member: 273691
any solution of lumia 510 blank display. windows key light is working but no display
Old 11-12-2013, 09:19   #6 (permalink)
ksm_lovers2000's Avatar
Member: 968250
Sonork: 100.1673266
Thanks Meter: 13
remove screen paper ur problem solved100%
Old 11-13-2013, 11:03   #7 (permalink)
Member: 273691
There in no screen protevtor problem is blank display i have changed lcd but no display.
but phone is working fine. pls help.
Old 11-13-2013, 18:04   #8 (permalink)
Member: 422727
Thanks Meter: 3
u just remove light sensor
Old 11-20-2013, 10:00   #9 (permalink)
Member: 9753
Thanks Meter: 3
change light sensor or stick with 2 side glue.
Old 11-23-2013, 13:01   #10 (permalink)
Member: 1203610
Sonork: nayan12
it's censor light or censor problem try it
Old 03-02-2014, 15:51   #11 (permalink)
Member: 1709730
nokia lumia 510 key light ok but no lcd light
Old 03-02-2014, 16:01   #12 (permalink)
Member: 925748
Thanks Meter: 5
Just change d touch screen prob solved 100%
Old 03-04-2014, 06:55   #13 (permalink)
Member: 1584831
Thanks Meter: 43
i think its a sensor problem..................
Old 03-08-2014, 19:26   #14 (permalink)
bright hlatini's Avatar
Member: 1614640
Sonork: 100.1625899
Thanks Meter: 335
l have a nokia lumia 510 ,when the display light goes off to standyby the phone immediately restart,,,how can l solve this plizzzz
Page generated in 0.32693 seconds with 8 queries
