Old 09-26-2003, 00:18   #1 (permalink)
Member: 847
Thanks Meter: 36
Made bridge in 3410, can i leave it this way?
Hi.
Have 3410 with little waterdamage in L513 area.
Didnt power on.
Made bridge from L513 to C575.
Can i leave it this way, no danger off melting phone ?
Thanks
Sjakie
Old 09-26-2003, 02:38   #2 (permalink)
Member: 39601
Thanks Meter: 13
Check continuty L513 bothe ends,C575,L201,C247,and C404.
That covers most of hte +ve line.
Then check volts on the PCB, befor and after power-on ignesion
If U fineds volts on the keypad about 2.8 and stable , try to
flash the phn.
If U want to put a permanent bridges U can use a wax insulated wires(from any old radio cassette motor,but be sure of soldering
to the copper under the wax) good luck.
Old 04-08-2004, 01:10   #3 (permalink)
blue1's Avatar
Member: 60613
nice reply medz
is it truth - with this way run your simemu in locked 3g iphone eurka Sim Cloning and Scaning 0 12-21-2008 12:49
V3i when i keep using it works perfect but if i leave it it hang and freez???? tsarkh Motorola P2k 1 10-20-2008 10:51
Ok do it this way (no answer) erlise Seking Server 1 05-04-2008 19:27
Can C28 & C25 V6x unlock in this way B.H x1x to x45/x50 2 11-30-2000 13:37
Page generated in 0.12304 seconds with 9 queries
