Memory Card Forgotten Unlock Code Pls Help Me How To Reset Unlock Code Of Memory Card Of Nokia 6600. |
best regards, Irinel |
or u can try N9210i in formatting ur mmc..... |
Best regards, Irinel |
how reformat in n9210i? i tried viewing using memory card reader in computer but it says "insert card in drive F". i cant view the files in computer. help...... |
install an search software in your 6600, find the and send the mmc detail datas in your desktop with Bluetooth. open this file with editor, in you see inside your pass. enjoy. |
Format the mmc card on 9210i works 100% :) |
1:install the select Q to that mmc lock phone 2:open the select Q 3:go option 4:go find then type MMCSTORE then press the centre button 5:it well find one data folder then send this for to ur pc 6:at pc u well see the one text file (MMCSTRORE) 7:rename the (MMCSTORE.TXT) 8:open the text file u will see the pw REMEMBER MUST USE THAT MMC LOCK COCE PHONE IF USE ANOTHER PHONE CANT WORK. ;) ;) ;) |
Try this method also,it appears the same idea but with other tools. 1-Setup seleQ or handyfile program on the phone locked 2-Open C:/System 3-You will find file is named mmcstore copy it to another folder. 4-Rename it mmcstore.txt you will find the password There. Also you can send this file to computer and open it This method work on 6600,3650,3660,7610 |
To B-phreax: what file in MMc do i have to open using editor? |
select Q ?? Quote:
Is it a program? where could I download "select Q" ? :eek: Regards |
this is good solution but i have problem, my nokia 6600 reflash again, and i forgot the unlock code for mmc How to resolve this problem dude? |
handyfile 1 Attachment(s) To yaren handyfile is equal to seleQ it's application its extension (handyfile.sis) must be setup on the phone. |
Hi dear this is just **** i try 9210i,9500 to format memory card but in file manager>format memory card can't highligt and also can;t highlight change password how i format this f*u*c*k card |
you can reformat your memory card.using another phone .......... try this application now..........or you return this memory card back to the sales dept. bestman |
