10-30-2008, 15:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: JALANDHAR(PUNJAB)
Member: 727235 Status: Offline Sonork: [email protected] Thanks Meter: 1,211 | ..::mobiles network related post::.. HOW TO FIND WHICH SECTION IS FAULT Tx (or) Rx? Testing Rx section use manual search for Testing Rx section, after searching Rx section good condition means it shows network list like Airtel, hutch, (or) any other network list in your area, If Rx section bad condition after searching it shows NO NETWORK FOUND 1, after searching it shows network list means Rx section is ok. 2, after searching it shows NO NETWORK FOUND means Rx section is fault. Testing Tx section Use manual search for testing Tx section, after searching it shows network list, then you can choose your simcard network, if Tx section is good condition it shows HOME NETWORK SELECTED, if Tx section is fault it shows NO ACCESS. 1, after selecting network it shows HOME NETWORK SELECTED means Tx section is ok. 2, after selected network it shows NO ACCESS means Tx section is fault. Information of Rx section components and ics nokia dct-3 tech 1, antenna switch 2, RF IC ( Hagar ic ) 3, AUDIO IC ( cobba ic) 4, crystal oscillator 5, filters 6, VCO (voltage control oscillator) Information of Tx section components and ics nokia dct-3 tech 1, PF IC (PA IC) Information of Rx section components and ics nokia dct-4 tech 1, antenna switch 2, filters 3, RF IC 4, crystal oscillator 5, VCO (voltage control oscillator) 6, UEM IC Information of Tx section components and ics nokia dct-4 tech 1, PF IC (PA IC) HOW TO SERVICE Rx SECTION FAULT ? Solution for Rx section no network found fault nokia dct-3 technolagy 1,clean the pcb well and Rehot (if not ok follow one by one solutions) 1, give antenna switch jumper 2, Rehot the RF IC 3, Rehot the AUDIO IC 4, Reball the RF IC 5, change the RF IC 6, change the AUDIO IC 7, change the crystal oscillator Solution for Rx section NO NETWORK FOUND fault nokia dct-4 technology 1, clean the pcb well and Rehot (if not ok follow one by one solutions) 2, give antenna switch jumper 3, Reheat the RF IC 4, change the crystal oscillator 5, Reball the RF IC 6, change the RF IC 7, Change filters HOW TO SERVICE Tx SECTION FAULT ? Solution for Tx section NO ACCESS fault nokia dct-3 technolagy 1, Change the PF IC Solution for Tx section NO ACCESS fault nokia dct-4 technolagy 1, Change the PF IC SOLUTION FOR OTHER NETWORK FUALT Solution for low network coverage, all models 1, give jumper from antenna contact to cabinet antenna 2, change the antenna switch Solution for dct-3 technology When switch on the mobile it shows full network after few seconds its goas down 1, flash - Rebuild ime - UI settings (if not ok follow 2nd solution) 2, check the track from battery +ve point to PA IC, if track is ok then change the good PF IC. Solution for dct-4 technology When switch on the mobile it shows full network after few seconds its goas down 1, write good pm file (if not ok follow 2nd solution) 2, change the PF IC, if still the problem same check the PF power track to battery +ve point. |
The Following User Says Thank You to bgreat For This Useful Post: |
10-30-2008, 15:29 | #2 (permalink) |
Freak Poster Join Date: Jul 2008 Location: india Age: 39
Member: 812373 Status: Offline Sonork: [email protected] Thanks Meter: 47 | hi: bgreat::: very hard wark.....good job.. thanx ..... |
..::mobiles network related post::..gopalhot | gopalhot | Nokia Hardware & Hardware Repair | 2 | 07-15-2008 19:38 |
..::plz read and poll this post::.. | HUM | Off Topic Zone | 18 | 05-13-2008 01:41 |
Is There Any Relation to Unlocking and Loss of network...please answer 911GT | harim_1981 | MT-BOX | 10 | 10-23-2007 09:49 |
..::Mobile Start CHARGING.When connect Cable::.. | zakiyyboss | Cruiser Suite | 14 | 10-16-2006 02:13 |
