03-06-2002, 03:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Most Simple 24Cxxx Programmer Ever! Below is the worlds most simple EEPROM programmer for 24Cxxx with Pony Prog. No components needed, just wires and a DB-9 Female Connector. COM Port PIN3 -------------Connect to-----> EEPROM PIN8(VC) COM Port PIN4+PIN8 -------Connect to-----> EEPROM PIN5(SDA) COM Port PIN5 -------------Connect to-----> EEPROM PIN4(GND) COM Port PIN7 -------------Connect to-----> EEPROM PIN8(SCL) Configure Pony Prog Hardware to: Serial SI Prog API OR Serial S/I Prog I/O Tips and Tricks: 1. On some phones, you can read EEPROM contents without removing the IC from the PCB. To do this, you must connect a fast charger to the PCB so that there would be enough power for programming... (Because neighboring ICs tend to steal power during I.C.P. <In-Circuit-Programming). You can do this easily on 61xx/51xx, but you will have problems with 3210s... 2. On some phones, you cannot program EEPROM even if you connect fast charger. For these phones, you must lift PINs 5,6,7,8 from the PCB and leave PINs 1,2,3,4 still soldered on the PCB. Now solder wires to the PINs 5,6,7,8 and connect it to your EEPROM programmer. Don't forget to solder GND to any exposed GND on PCB. You don't need to connect fast charger anymore. 3. When EEPROM is still on PCB, there are some memory areas that you cannot reprogram. You must lift PINs 5,6,7,8 to be able to program the entire memory area! Warning: The "No Components" EEPROM programmer is my own design, but you must use it at your own risk. Many might think that this design is far too risky because it is not regulated in any sense. I will not be reponsible if you will damage EEPROMs while using my design, but I can assure you that my design works on almost 100+ phones in reparing all locks closed EEE FFFF a long time ago. Best Regards, X-Shadow |
03-06-2002, 13:22 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Latvia Age: 48
Member: 3973 Status: Offline Thanks Meter: 0 | Hi X-Shadow !!! You write two pin's8 on eeprom. VC and SCL. It is mistake or no? COM Port PIN3 -------------Connect to-----> EEPROM PIN8(VC) <--- !!!!! COM Port PIN4+PIN8 -------Connect to-----> EEPROM PIN5(SDA) COM Port PIN5 -------------Connect to-----> EEPROM PIN4(GND) COM Port PIN7 -------------Connect to-----> EEPROM PIN8(SCL) <--- !!!!! |
03-06-2002, 13:43 | #3 (permalink) |
Registered User Join Date: Feb 2002 Location: universal
Member: 9538 Status: Offline Thanks Meter: 1 | if you want to read eeprom of 5110 (24c16) and 6110 (24c65), you don"t need any pony programmer tools and hardware, you can use nokiasp 1.0.1 to dowdload and upload the eeprom, if it was a higher version , and not support, the easy way is to downgrade the firmware use rolis 4.77, after that you can download your eeprom and upload it. |
03-07-2002, 09:00 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | NOKIA SP CANNOT DOWNLOAD SECURITY AREA OF EEPROM........ i tested on my 6110 i repaired my 6110 with the bin file i had but it works only WITH MY OWN PHONE......with no other phones it was working........... |
03-07-2002, 09:35 | #5 (permalink) |
Crazy Poster Join Date: Feb 2002 Location: Greece Age: 46
Member: 9711 Status: Offline Thanks Meter: 0 | Security area ROM3 Thank U!!!!! I wasn t sure if that was the problem with NokiaSP. That EEPROM security area...can it b downloaded with that Simple programmer????? Having a ROM3 5110...(24C16) i don t know how to repair it!! I need some info please. The phone has NO NETWORK and Reboots!!! |
03-07-2002, 11:55 | #7 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | Hello Guys.... Sorry for mistake, here is corrected scheme: COM Port PIN3 -------------Connect to-----> EEPROM PIN8(VC) COM Port PIN4+PIN8 -------Connect to-----> EEPROM PIN5(SDA) COM Port PIN5 -------------Connect to-----> EEPROM PIN4(GND) COM Port PIN7 -------------Connect to-----> EEPROM PIN6(SCL) Best Regards, X-Shadow |
Teleway and ONE-STOP-FACTORY are the most honest person I've ever seen! | Qbe | The Market Feed Back | 7 | 02-18-2004 11:30 |
Most powerfull MOTOROLA V6x, V70 & T280 unlock/flash tool ever... | Spalato | Main Sales Section | 0 | 08-11-2002 18:49 |
Most strange 3310 thing I've ever seen | Safrane | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 06-12-2002 03:07 |
