Old 01-21-2003, 15:23   #1 (permalink)
Member: 4398
Damaged solder pads ? Is there any way to repair them ?
People keep asking me if i can repair damaged solder pads where leds have been ripped off the board or where power switches have been pulled off.
Is there anyway to make the solder stick to the contact ?
Old 01-21-2003, 16:08   #2 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
one way to do it is use some super glue to stick the new acting pad. This however is according to where you are using it. If it is the switch then it msut be strongly and firmly held else it wil lgive way.
g luck
al
Old 01-21-2003, 18:15   #3 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
hi burnt ?
super glue is conductive ? what about connection from
x y z part ?
to simbirley,
i use diod's or resister's thick wire. one side at pcb's ground
and other at switche's ground leg. then second to supply
and then super glue.
Old 01-21-2003, 20:27   #4 (permalink)
Member: 1060
Thanks Meter: 10
Re: Damaged solder pads ? Is there any way to repair them ?
simbirley
might you have to search it first . and you can read this:
http://forum.gsmhosting.com/vbb/show...threadid=68845
Willy
CONFIG KEY: 0000000000000000 is there any way to repair this! ATSC L.L.C Universalbox 8 03-20-2009 09:17
CONFIG KEY: 0000000000000000 is there any way to repair this! ATSC L.L.C J.A.F. By Jafsupport.com 0 01-21-2009 14:04
Is there any way to repair imei on M6100? Burnt Cobba VygisToolbox 3 11-25-2007 21:28
Is there any way to repair "Contact Service" Using Dejan Flasher.? AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 04-26-2001 03:41
Is there any way to repair "Contact Service" Using Dejan Flasher AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-19-2001 22:08
Page generated in 0.15547 seconds with 10 queries
