Old 08-17-2003, 15:02   #1 (permalink)
mobilemafia's Avatar
Member: 7889
Thanks Meter: 7
Exclamation my 6610 shows contact service
i tried sp unlock with griffin successfull
but phone is contact service
also today with version 2.02 tested self test
all test passed
and i seen that product code second last digit is diffrent from original one
repaired product code still phone is contact service
how to repair
any clue
also after self test phone shows insert sim but there is no network
i cant make emergancy call
Regards
[email protected]
Old 08-17-2003, 15:40   #2 (permalink)
Member: 11726
Thanks Meter: 10
HI m8...
For repair contact service put phone in test mode & then press unlock buttom in griffin thats all.
good luck
Old 04-08-2004, 01:57   #3 (permalink)
blue1's Avatar
Member: 60613
how it became con serv?
Old 04-08-2004, 06:38   #4 (permalink)
a4tech's Avatar
Member: 26377
Originally Posted by fantom
HI m8...
good luck
doesnt work on my side....and can i manually put the phone in test mode?
Old 04-08-2004, 10:52   #5 (permalink)
a4tech's Avatar
Member: 26377
problem with 6610 contact service "solved"..... i think you cannot PUT the phone in test mode...as to my understanding....
Old 04-10-2004, 15:37   #6 (permalink)
Member: 44658
try to rebuild the IMEI twice...
Old 04-11-2004, 04:27   #7 (permalink)
a4tech's Avatar
Member: 26377
Put the UNIT in LOCAL MODE First and click "UNLOCK"... thats it... try it first to software solution...if not ENGINEER's solutions will be the option...
Old 04-12-2004, 09:34   #8 (permalink)
Member: 50240
sometime you cannot remove contact service on the phone even after using griffin so u should first clean the phone pcb, then unlock phone with griffin ......
that occured to me once..
Old 04-14-2004, 15:59   #9 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
upgrade your software first, unlock the phone again, if the phone was working 100% befor unlock do not try to open the phone and clean...etc. its a software problem.
you can try to relock the phone to any network you want and unlock again.
My 5130c is showing Contact Service smsismail HWK 3 01-19-2010 08:57
nokia 6610 i contact service pankaj_gsm Nokia Hardware & Hardware Repair 7 07-06-2009 19:32
my lg KX256 SHOWS CONTACT SERVICE CENTER WITH UIM CARD mobayk Various CDMA/TDMA Cell Phones 2 02-16-2009 19:09
6610 i contact service gsmservices Nokia Digital Core Technology 4 ( DCT-4 ) 1 06-21-2005 17:37
Page generated in 0.15483 seconds with 9 queries
