07-21-2006, 06:51 | #3 (permalink) |
Freak Poster Join Date: May 2003 Location: MADAGASCAR Age: 42
Member: 28378 Status: Offline Thanks Meter: 3 | Before flashing did your phone work properly? Do you know which version was inside your phone before ? Usually, flashing the latest firmware will solve your problem, Full flash it, then Full UI defaults, Unlock, and format User Area..... if you have #phone startup faillure, contact provider#..... |
07-21-2006, 07:08 | #6 (permalink) |
Junior Member Join Date: Jul 2006
Member: 315540 Status: Offline Thanks Meter: 1 | I try after flash again also can not.... VVVVVVVVVVVVVVVVVVVVVVVVVVV 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT Algorithm: w3_amd.fia, w3_cbusb.fia, Ver: 4.52.0 Algorithm Ok, MSID: 843680EBD218A537D8B6FFB668 Decoded MSID: 3E4EBAF7-009CAF0A-A9000000 Encoded FAID: 6B4120BE-ED766ABB-6C91AA1C Area1: 0x00000000-0x0000FFFF Erased, Time: 0:00 Area2: 0x00010000-0x007FFFFF Erased, Time: 1:09 Area3: 0x04000000-0x046FFFFF Erased, Time: 0:59 Area4: 0x06000000-0x067FFFFF Erased, Time: 1:14 Area5: 0x02000000-0x0217FFFF Erased, Time: 0:13 Area6: 0x047C0000-0x047EFFFF Erased, Time: 0:01 BT MCM (21) Image Found: 0x0002DD94 BT MCM Registering Done MCU Flashing Completed, Time: 5:06 Flashing Completed, Rebooting Mobile Set Full Factory Defaults Failed |
07-21-2006, 07:45 | #7 (permalink) |
Member: 28378 Status: Offline Thanks Meter: 3 | You need to put correct flash file before setting UI defaults.... The flash file you choose is APAC (for asia pacific regions). If it was the original flash inside your phone, then your phone is dead because you donwgraded it. To repair, you need to Upgrade the firmware: Flash it with NHL105530.C1... wich is newer than yours.... Full flash MCU+PPM If u use tornado, select UI factory defaults, Full factory defaults, Soft upgrade defaults, init simlocks. After flash, do not remove the cable untill all UI settings process are finished because it will be difficult to get your phone in test mode. If Ui settings fails... U have to repeat and repeat untill the phone gets into test mode. Do not forget to select format user area at the end..... If you can not format user area, do it manually, Hold (*), (3), (green), and power keys at the same time untill you will see formatting on the LCD. Formatting user arear will delete all data inside the phone but it will fix the #phone startup failed# problem. ENjoy |
07-21-2006, 07:58 | #8 (permalink) | |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | Quote:
07-21-2006, 09:13 | #9 (permalink) |
Member: 315540 Status: Offline Thanks Meter: 1 | now the phone appear i use flashfile MCU=>Nhl105530.c1 PPM=>Nhl105530.34 VVVVVVVVVVVVVVVVVVV 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT Algorithm: w3_amd.fia, w3_cbusb.fia, Ver: 4.52.0 Algorithm Ok, MSID: 843680EBD218A537D8B6FFB668 Decoded MSID: 3E4EBAF7-009CAF0A-A9000000 Encoded FAID: 6B4120BE-ED766ABB-6C91AA1C Area1: 0x00000000-0x0000FFFF Erased, Time: 0:00 Area2: 0x00010000-0x007FFFFF Erased, Time: 1:10 Area3: 0x04000000-0x046FFFFF Erased, Time: 1:23 Area4: 0x06000000-0x066FFFFF Erased, Time: 1:05 Area5: 0x047C0000-0x047EFFFF Erased, Time: 0:01 BT MCM (21) Image Found: 0x0002DD94 BT MCM Registering Done MCU Flashing Completed, Time: 4:30 Area1: 0x00000000-0x0000FFFF Erased, Time: 0:00 Area2: 0x02000000-0x020DFFFF Erased, Time: 0:07 PPM Flashing Completed, Time: 0:10 Flashing Completed, Rebooting Mobile Init Test Mode Failed IMEI: ---, ASIC: |
ns pro dead my g800 during patch need help | ..::Mobile Smoker::.. | NSPRO | 3 | 03-25-2008 18:33 |
My smart dead in update!!!help me!! | dian8dian | Smart-Clip | 1 | 10-16-2007 07:23 |
my KG110 dead on vygis help pls..... | cora | VygisToolbox | 5 | 03-12-2007 22:25 |
Dead C975 answer but I also need help | helplease | Motorola P2k | 3 | 08-01-2006 18:53 |
mY N6600 DEAD after flashing pm | Schnitzer | WD2 & APE (Symbian Phones) | 2 | 03-01-2006 17:28 |
