My Nokia Hardware Repairing Technics 1110,1112,1600,2310,2610,6030 SOME TIMES POWER ON,SOME TIMES BLUE DISPLAY,SOME TIMES HANG NOKIA LOGO THIS HANDSETS SOFTWARE CONNECTING TIME MANY DIFFERENT ERROR SHOW. ERROR1) MCU ID: 0x2201 FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 25:06:2008 14:14 -> AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... BOOTING NOT COMPLETED ERROR2) MCU ID: 0x2201 chk Failed! Aborting! ERROR3) Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line ERROR4) SOME TIMES SHOW UPP DAMAGED OR UEM DAMAGE ERROR SHOW!!!!!!!!!!! AM EXPLAIN HOW TO SOLVED THIS PROBLEM 1)FIRST CHECK EASY CABLE PORT A)CLEAN OR CHANGE THIS CONNECTOR B)CHECK PCB CONTECT PICTUER NUMBER-1 http://i193.photobucket.com/albums/z...a/PICTURE1.jpg 2)CHECK BATTERY CONNECTOR A)RESOLDRING BATTERY CONNECTOR OR CHNAGE IT PICTURE NUMBER-2 http://i193.photobucket.com/albums/z...a/PICTURE2.jpg 3)CHECK BSI LINE A)CHECK PICTURE NUMBER-3 http://i193.photobucket.com/albums/z...a/PICTURE3.jpg 4)CHECK BSI RESISTER A)FIRST REMOVE THIS RESISTER THEN CONNECT SOFTWARE B)SAME ERROR SHOW? CHANGE THIS RESISTER http://i193.photobucket.com/albums/z...a/PICTURE4.jpg |
5)CHECK SECOND LOCAL OSILLATOR 26Mhz CRYSTAL A)CHNAGE THIS CRYSTAL http://i193.photobucket.com/albums/z...a/PICTURE5.jpg 30%UEM PROBLEM 20%UPP PROBLEM REGRADS SHIJILFONOTLY&NEILTHIRUMUTTAM NOKIA.REPAIR.MASTERS.TEAM |
INSERT SIM SOLUTION 1110,1112,1600,2310,2610,2310 1)CHECK OR CHANGE BATTERY&SIM CARD----BOTH ITEAMS AFTER CHANGING SAME INSERT SIM PROBLEM? 2)OPEN HANDSET THEN CHECK THIS PARTS A)BSI VOLTAGE MISSING PHONE SHOW INSERT SIM http://i193.photobucket.com/albums/z...--PICTURE3.jpg B)CHECK EASY CABLE PORT OR PCB CONTCAT http://i193.photobucket.com/albums/z...a/PICTURE1.jpg C)CHECK VSIM LEG Ohms FIX MULTI METTER TO DIODE CHECKING MODE a)(DIFFENT VALUE OHMS SHOW ABOVE 500ohms?----(VSIM VOLTAGE PREFECT) b)(SAME VALUE OHMS SHOW?LIKE 200 Ohms TO 200 Ohms,(VSIM RELATED CAPACITOR SHOTAGE)40%UEM(REMOVE RED MARKED CAPACITOR) http://i193.photobucket.com/albums/z...---PICTURE.jpg c)NOT SHOW ANY VALUE Ohms?(UEM NOT GENARATE SIM VOLTAGE 100M PROBLEM)BUT ONE THINK VSIM PRINT MISSING NOT SHOW ohms http://i193.photobucket.com/albums/z...---PICTURE.jpg CHECK RED MARKED WAYS |
D)REMOVE SIM IC THEN CHECK SIM CONNECTOR TO SIM IC WAYS http://i193.photobucket.com/albums/z...yschecking.jpg E)CHNAGE OR SHOT SIM IC http://i193.photobucket.com/albums/z...ingmethode.jpg LAST CHECK UEM AND UPP RESULT 1)SIM,BATTERY,SIM IC,SIMWAYS,CAPACITOR SHOTAGE ETC......65% 2)UEM............................................. ......20& 3)UPP............................................. ......15& REGARDS SHIJILFONOTLY&NEILTHIRUMUTTAM |
more Update Comming Soon Now Am Prepair Bb5 Handsets |
3 Attachment(s) brother this my repairing idea 1)POWER ON PHONE WITH SIM THEN GOTONETWORK SETTINGS OPTION AND USE MANNUL SEARCH OPTION.THIS TIME PHONE SHOW2 MESSAGES 1 IS NO NETWORK FOUND 2nd IS DETECTED ANY NETWORK PROVIDER NAME 1)NO NETWORK FOUND 60%HARDWARE 40%SOFTWARE 1)WRITE TESETED PM(PM FILE HERE) 2)CHECK AN****A OR AN****A PAD 3)REMOVE AN****A SWITCH THEN MAKE JUMBER LIKE THIS PICTURE 3)CHANGE RX&TX FILTER(BLUE MARKED) 4)CHANGE SECOND LOCALCRYSTAL NEAR IF IC(CAREFULL NET WORK IF IC GLUDE OVER HEAT DAMAGED THIS IC)RED MARKED 5)CHANGE FDKVCO THIS ALL ITEAMS CHANED AND CHECKEDSAME PROBLEM? 60% UEM OR 40%UPP PROBLEM 2nd IS DETECTED ANY NETWORK PROVIDER NAME THEN WHICH PROVIDER SIM USE SEARCHING TIME JUST SELECT AND REQUEST THIS NET WORK THIS TIME PHONE SHOW NET WORK NO ACCESS? THIS HARDWARE PROBLEM BUT ONE THINK PM FILE PROBLEM SOME TIMES PHONE SHOW THIS ERROR(WRITE THIS PM) 1)REFLOW PA 2)CHANGE PM 75%PA PROBLEM POST RESULT |
1110,1110i,1112,1600,2310 NOT CHARGING STEP BY STEP REPAIRING WITH MY IDEA 1110,1110i,1112,1600,2310 NOT CHARGING STEP BY STEP REPAIRING WITH MY IDEA 1)CHECK OR CHANGE BATTERY OR CHARGER http://i193.photobucket.com/albums/z...r-acp12e_1.jpg http://i193.photobucket.com/albums/z...kara/bl-5c.jpg 2)SOME TIMES PM FILE PROBLEM PHONE SHOW NOT CHARGING A)WRITE THIS PM 2)OPEN HANDSET THEN CHECK EASY CABLE PORT OR CHARGER SOCKET A)CHANGE THIS PART 3)CHECK CHANGER INPUT RELATED ESD,CAPACITOR,FUSE AND COIL http://i193.photobucket.com/albums/z...reWiz009-1.jpg 4)CHECK BSI WAYS http://i193.photobucket.com/albums/z...a/PICTURE3.jpg |
5)REMOVE BSI LINE FILTER CAPACITOR NEAR BATTERY CONNECTOR http://i193.photobucket.com/albums/z...tureWiz007.jpg 6)REMOVE BSI REALTED RESISTER THEN CHECK CHANGERING SAME NOT CHARGE SHOW FIX THAT RESISTER http://i193.photobucket.com/albums/z...a/PICTURE4.jpg 7)CHNAGE THIS RESISTER LIKE THIS PICTURE http://i193.photobucket.com/albums/z...tureWiz008.jpg 8)TRY TO CHNAGE BSI OR BTEMP RELATED RESISTER OR CAPACITOR http://i193.photobucket.com/albums/z...tureWiz010.jpg 40% UEM PROBLEM PHONE SHOW NOT CHANRGING |
Nokia N70 White Screen Reapiring Step By Step TWO TYPES WHITE SCREEN PROBLEM 1St IS WHITE SCREEN FREEZED(non booted) THIS TIME PHONE NOT BOOTED,POWER ON TIME JUST ENABLED DISPLAY&KEYPAD LIGHT ONLY HOW TO CLEAR THIS PROBLEM--------AM EXPLAIN MY EXPERIANCE A)CONNECT JAF,UFS OR MT BOX ETC............. B)USE CHECK BUTTON Booting phone... APE Boot Data: Asic ID: 17100701 Asic Mode ID: 00 Asic Public ID: C57A6C30A60BFE52D39FC1751D66A629FB40EB4E HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 1E80000999865A516630285C29EAFDD6F54AA796 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\helen3_2nd.fg Loader version: 01.23.00 -> Revision: 0000 Patching APE boot step2... APE Boot Ready APE Flash ID: 00360098 <=> SAMSUNG -> Type not in database APE Flash Data: 00020000000600000000000000000000 Done! C)CHANGE PHONE MODE TO LOCAL MODE(WHITE SCREEN FREEZED PHONE MUST ENTER LOCAL MODE) Changing mode... Done! D)THEN AGAIN CHANGED PHONE MODE TO TEST MODE(WHITE SCREEN PHONE NOT ENTER TEST MODE) BECOZ OMAP WORKING NOT PROPER Changing mode... Failed!!! REPAIR SOLUTION STEP1---CHECK IN PUT SMPS VOLTAGE(3.6VOLT) A)THIS VOLTAGE MISSING? JUST MAKE THIS JUMBER http://i193.photobucket.com/albums/z...ara/STEP-1.jpg STEP2---CHECK DC/DC CONVERT COIL OUT VOLTAGE IN SAME VAULE(1.4VOLT-VCORE) A)COIL OUT VOLTAGE NOT SHOW? CHANGE THIS COIL http://i193.photobucket.com/albums/z...ara/STEP-2.jpg STEP3---CHECK SMPS OUT PUT VOLTAGE(1.4VOLT-VCORE) A)OUT VOLTAGE NOT SHOW? CHANGE THIS SMPS(50%SPMS PROBLEM) http://i193.photobucket.com/albums/z...ara/STEP-3.jpg STEP4---OMAP----30% STEP5---RAP3G---20% |
WHITE SCREEN,SOME TIMES POWER JUST SECONDS TRUN OFF,SOME TIME NOKIA LOGO HANGING ONLY SOLUTION HERE A)CONNECT JAF,UFS OR MT BOX ETC............. B)USE CHECK BUTTON Booting phone... APE Boot Data: Asic ID: 17100701 Asic Mode ID: 00 Asic Public ID: C57A6C30A60BFE52D39FC1751D66A629FB40EB4E HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 1E80000999865A516630285C29EAFDD6F54AA796 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Done! SEE THIS FLASHING LOGO FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V11 CNT Flash file: NONE APE Variant file: ? Manual mode selected, version can't be checked! Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 0C800103D8654E5160FC20C285A16EB1C330C054 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 CMT Loader Ready Operation took 0 minutes 6 seconds... Sending CNF Data... APE blocks present in flash file but no APE mcu detected in phone. Aborting! THIS PROBLEM MAINLY SHOW 2 CHIP FAILING APE DRIVER NOT DETECTED OR APE FLASH IC DAMAGE A)APE DRIVER NOT GENARATE VDRAM(1.8V) VOLTAGE SOLUTION STEP1---CHECK VBATT WAYS http://i193.photobucket.com/albums/z...akara/APE1.jpg STEP2---CHECK APE DRIVER OUTPUT VOLTAGE C4206 TO V7602,C5000 CHANGE APE DRIVER http://i193.photobucket.com/albums/z...akara/APE2.jpg STEP----REFLOW OR REBALL COMBO MEMORY http://i193.photobucket.com/albums/z...akara/APE3.jpg 50%APE DRIVER 40%COMBO MEMORY 10%OMAP |
ufs solved nokia 1600,1110,1112,2310 etc.....network problem with software ufs solved nokia 1600,1110,1112,2310 etc.....network problem with software how to check this model handset network problem HARDWARE OR SOFTWARE see this video mannul http://www.sendspace.com/file/k5m236 what is ur opinion |
comming soon new model nokia same type solution am prepairing now |
Nokia N70 White Display (booted) PHONE WHITE SCREEN BUT PHONE WORKING FINE(CALLING 100%OK) SOLUTION STEP BY STEP 1)CHANGE DISPLAY http://i193.photobucket.com/albums/z...ra/DISPLAY.jpg 2)RESOLDRING OR CHANGE DISPLAY CONNECTOR http://i193.photobucket.com/albums/z.../PICTURE-2.jpg 3)CHECK VI0(1.8V) OR VAUX(2.5V) A)VIO 1.8VOLTAGE NOT SHOW MULTI METTER? 1)CHECK C4400 TO C2215 WAYS LIKE THIS PICTURE(WAYS ARE OK?) 2)CHECK OR CHNAGE L4400 COIL OR REMOVE C4400,C2215 CAPACITOR http://i193.photobucket.com/albums/z.../PICTURE-A.jpg 3)AGIAN SAME VOLTAGE MISSING 100%RETU PROBLEM(VIO 1.8V GENARATED BY RETU) REFLOW OR CHNAGE RETU http://i193.photobucket.com/albums/z...URE-A3ORB3.jpg B)VAUX(2.5V) VOLTAGE NOT SHOW MULTI METTER? 1)CHECK C2216 TO C4401 WAYS LIKE THIS PICTURE(WAYS ARE OK?) 2)CHECK OR CHANGE L4401COIL OR REMOVE C4401,C2216 CAPACITOR http://i193.photobucket.com/albums/z.../PICTURE-B.jpg 3)AGIAN SAME VOLTAGE MISSING 100%RETU PROBLEM(VAUX 2.5V GENARATED BY RETU) REFLOW OR CHNAGE RETU http://i193.photobucket.com/albums/z...URE-A3ORB3.jpg VIO(1.8V)OR VAUX(2.5) prefect? A) REFLOW OR CHNAGE Z4402 OR Z4403 http://i193.photobucket.com/albums/z...vadakara/D.jpg B) SAME WHITE SCREEN PROBLEM AGAIN REMOVE 2 DISPLAY IC THEN CHECK DISPLAY CONNECTOR TO DISPLAY EMI WAYS http://i193.photobucket.com/albums/z...vadakara/B.jpg C)NOT SOLVED THIS PROBLEM 100%OMAP PROBLEM |
thanks sir please post vedio manual thanks |
