12-23-2004, 23:39 | #2 (permalink) |
Junior Member Join Date: Oct 2002 Age: 44
Member: 16363 Status: Offline Thanks Meter: 8 | Originally Posted by X-Shadow Simple Solution for 6600 "Contact Retailer" using Twister Software Step 1: Click ERASE Flash start address: 02000000 end address: 027FFFFF * if you get an "Erase Flash Error" message in a specific address in the flash ic, this means that you have a damaged flash IC. You will need to replace flash IC number 2 inside the phone. (The 6600 has 4 flash ICs inside). Step 2: If you are successfull in erasing flash IC number 2, make a full flash of the phone... MCU + PPM + Bluetooth if necessary. Step 3. If you are successfull in full flashing the phone, put battery inside phone and you SHOULD GET "Contact Retailer" message again. Now remove the battery, put it back and hold buttons "call(green button on the left)" + "*" + "3" then press the power button while still holding the 3 buttons above... The phone should start formating itself (note that there must be no sim card inside the phone while doing this...) After formatting, phone should be ok... but need to update a good PM file if necessary. Best Regards. |
12-25-2004, 05:53 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | if phone can power on and you need to flash it, before flash you must reset phone by code *#7370# after finish, now you can flash phone safety. use griffin to flash with this step: 1. power on griffin box 2. run griffin software 3. connect cable to phone to griffin box 4. detect phone (if phone can't detect go to number 6) 5. format user area 6. eraseflash (PPM only) 7. flash MCU+PPM 8. write PM file 9. Unlock 10. get succesfull |
01-11-2005, 21:49 | #8 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Up North
Member: 14934 Status: Offline Thanks Meter: 79 | Hello! i just wanted to say tnx tnx tnx for all the info in this thread, i did manage bring my 6600 back alive after reading this =) i did **** upp totally in the begining. i did write ppm file in mcu area of the flash... *shame on me* =p phone was dead, and i did read the posts above, now phone is alive and working again =) |
6600 dead after flashing with Griffin! | thedave | Griffin | 1 | 10-27-2005 05:46 |
6600 dead after flash | bubbles69 | WD2 & APE (Symbian Phones) | 2 | 03-16-2005 07:35 |
6600 dead after flash | majid2000 | WD2 & APE (Symbian Phones) | 8 | 12-26-2004 20:46 |
6600 dead after flashing with new 4.09.1 | mohd_anan | WD2 & APE (Symbian Phones) | 7 | 04-26-2004 06:55 |
