Old 03-04-2011, 17:03   #1 (permalink)
kashantariq2002's Avatar
Member: 1019981
Thanks Meter: 98
Thumbs up n 70 not on power
i have n 70 not power on chargig is ok im apply on off jumper not response im change on off resister not work pls help me
The Following User Says Thank You to kashantariq2002 For This Useful Post:
Old 03-04-2011, 17:13   #2 (permalink)
Member: 643367
change power ic , check power wayss
Old 03-04-2011, 17:17   #3 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
try this solution
The Following 2 Users Say Thank You to abdurrahimsagar For This Useful Post:
Old 03-04-2011, 18:20   #4 (permalink)
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,485
http://forum.gsmhosting.com/vbb/f148...e-way-1184403/
The Following User Says Thank You to abdurrahimsagar For This Useful Post:
Old 03-05-2011, 05:40   #5 (permalink)
Registered User
Member: 1179630
Sonork: 100.1644820
Thanks Meter: 80
N70 power switch way going via right side LCD IC
The Following User Says Thank You to wasangaama For This Useful Post:
Old 03-05-2011, 06:07   #6 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
yes bro but @abdurrahimsagar post
and make jumber
post result
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 03-05-2011, 16:22   #7 (permalink)
Member: 1019981
Thanks Meter: 98
thanks all to reply me i am solved problem im check mobile to power supply shown shortegs then i change display ic and check mobile is ok and perform well on off switch
Old 04-21-2011, 08:54   #8 (permalink)
pulsecom's Avatar
Member: 640386
Thanks Meter: 5
have same problem with N72 tried with jumber but not working.this is selftest results
Selftests to proceed: 31
Passed ST_TAHVOINT_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SLEEPCLK_FREQ_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_PWR_KEY_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_CMT_APE_WAKEUP_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_RADIO_TEST
Failed ST_HOOKINT_TEST
Failed ST_VIBRA_TEST
Passed ST_BTEMP_TEST
Failed ST_CDSP_RF_BB_IF_TEST
Failed ST_CDSP_RF_SUPPLY_TEST
Failed ST_CDSP_TX_IQ_TEST
Failed ST_CDSP_TXC_DATA_TEST
Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Failed ST_CDSP_GSM_TX_POWER_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_LPRF_IF_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_MAIN_LCD_IF_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_BT_SLEEP_CLK_TEST
Selftests done, Tests total: 31, Tests passed: 21, Tests not passed: 10
Old 05-04-2011, 12:25   #9 (permalink)
Member: 728300
Thanks Meter: 18
[IMG]http://*******.com/forums/attachment.php?attachmentid=13562&d=1189974704[/IMG]
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.26870 seconds with 10 queries
