Old 01-11-2009, 11:42   #1 (permalink)
Member: 555919
Thanks Meter: 70
7610 Not charging
7610 Not charging
need help to solve the problem or any jumper to remove not charging from 7610
The Following 2 Users Say Thank You to sal_pak For This Useful Post:
Old 01-11-2009, 12:15   #2 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
try change charging ic...
if u u do and the prblem still same, then rehot uem or change it..
Old 01-11-2009, 15:04   #3 (permalink)
Member: 555919
Thanks Meter: 70
you mean to say small charging ic
i have change this
Old 01-11-2009, 15:17   #4 (permalink)
Member: 555919
Thanks Meter: 70
any one please give me any other solution
Old 01-11-2009, 16:27   #5 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
http://forum.gsmhosting.com/vbb/atta...8&d=1170924122
try & post result..
Old 01-11-2009, 16:31   #6 (permalink)
Member: 581178
Thanks Meter: 438
1st write pm aftr
http://forum.gsmhosting.com/vbb/atta...6&d=1101720677
try this...
Old 01-11-2009, 19:31   #7 (permalink)
Member: 675717
Thanks Meter: 125
Change UEM no way.Thanks
Old 01-11-2009, 20:14   #8 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
Originally Posted by sal_pak View Post
7610 Not charging
here is tested pm file for 7610 not charging
http://forum.gsmhosting.com/vbb/atta...5&d=1122364465
just write this post result
it worked for me 1000%
check post result
Old 01-11-2009, 20:25   #9 (permalink)
Member: 736655
Thanks Meter: 123
7610 Not charging
try :
1. full erase
2. flash
3. write Pm
4. init simlock
5. format use area n do not full factory
this good pm :7610-***.rar
Old 01-11-2009, 20:29   #10 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
try to wright good pm if same then problem in uem
Old 01-12-2009, 04:44   #11 (permalink)
fasany's Avatar
Member: 841015
Sonork: 100.180803
Thanks Meter: 63
1st charging ic ways and their part..
2nd bsi line and behind battery connecter
3rd software..
*****last one UEM...****
any other that i missed?
Old 01-12-2009, 06:09   #12 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
Brother here is your solution................
[IMG][/IMG]
The Following 2 Users Say Thank You to prakash6464mh For This Useful Post:
Old 01-12-2009, 08:29   #13 (permalink)
Member: 598303
Thanks Meter: 7
write pm file it may be working
Old 01-12-2009, 08:40   #14 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
write pm
and re hot uem
then post reply
Old 01-12-2009, 14:35   #15 (permalink)
Member: 555919
Thanks Meter: 70
[IMG][/IMG]
not working i also re hot uem but still sAME
7610 not charge hussam qulfa WD2 & APE (Symbian Phones) 1 11-28-2005 16:26
7610 not charging bongiov Nokia Hardware & Hardware Repair 7 08-15-2005 18:35
7610 not charging bongiov Nokia Hardware & Hardware Repair 1 08-01-2005 17:15
7610 Not Charging after erase Faster Update WD2 & APE (Symbian Phones) 6 07-26-2005 08:55
nk 7610 not charging loverchew Nokia Hardware & Hardware Repair 1 06-28-2005 00:21
Page generated in 0.59264 seconds with 10 queries
