Old 01-03-2011, 13:52   #1 (permalink)
Member: 1126929
Thanks Meter: 27
N 70 phone start-up faild contact the retailer urgat
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: 257F329164D1CC9213B721AB0518D7853F4ED96E
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 04B00016A56468517C5E69B09D7FE6ED60680EAA
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE
ALG [35]: OMAP1610 GBBM-1.8.1 ALG
ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000
Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908
APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
Original Imei: 358 ok
Original Product code: 0539276
Bluetooth ID: 001D6E0E75D6
Phone Type: RM-84 (Nokia N70)
SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
Imei plain: 35808 ok
Product Code: 0530495
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3580 ok
Version: SIMLOCK SERVER VERSION 58
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
The Following User Says Thank You to sachinnahar143 For This Useful Post:
Old 01-04-2011, 17:47   #2 (permalink)
Member: 1126929
Thanks Meter: 27
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Imei net: 3580 ok
Counter: 0/3, 0/10
helpppppppppppppppppppppppppppppp
Old 01-04-2011, 17:51   #3 (permalink)
Crazy Poster
Member: 1484572
Thanks Meter: 13
if u have full pm backup restore them..................
Old 01-04-2011, 18:55   #4 (permalink)
Member: 1126929
Thanks Meter: 27
dietal helppppppppppppppppppp
Old 01-04-2011, 19:10   #5 (permalink)
Member: 1126929
Thanks Meter: 27
BUS Check
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Original Imei: 358080 ok
Imei plain: 358080 ok
Product Code: 0539276
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
[SIZE=1]
Imei net: 35808 ok
Counter: 0/3, 0/10
Scen
[B][COLOR=#ff0000]Phone Type: RM-84 (Nokia N70)
ApeCoreSw: V 5.0737.3.0.1
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
[SIZE=1]
Imei net: 358080 ok
Counter: 0/3, 0/10
BLOCK 1: [B]1=CORRUPTED
Old 01-04-2011, 19:10   #6 (permalink)
shaikhaltaf_m's Avatar
Member: 510263
Sonork: 100.1601350
Thanks Meter: 99
brother us mx key update sim lock
Old 01-04-2011, 19:32   #7 (permalink)
Member: 748400
Thanks Meter: 1,429
Thumbs up hiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Imei net: 3580 ok
Counter: 0/3, 0/10
for solve this problim go to universal box and select write to phone than select rm-10 rpl pm than reapair it with universal box and fonne seccsusful powred a solved many n70 with this solition
Old 01-04-2011, 21:49   #8 (permalink)
Member: 1287530
Thanks Meter: 3
you need update sim lock us mx key
Old 01-04-2011, 23:43   #9 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
yes man, u need update simlock,its mean want to be unlock,,then post result,
if all certs is fine then change avilma ,power ic and post result
br
ali
Old 01-05-2011, 17:03   #10 (permalink)
Member: 1126929
Thanks Meter: 27
update sim lock us mx key problam
Product: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
Using cached productData[04B00016A56468517C5E69B09D7FE6ED60680EAA] ...
Calculating SIMLOCK using security server ...
SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5
Completed in 1 min 29.609 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-84_358080 ok _SIM.RPL"
Updating SIMLOCK...
error 0x1
Reading Simlock info ...
Imei net: 35 ok
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 01-05-2011, 17:40   #11 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
br.hwk pormat fs.
univaras box least vr,flach
Old 01-05-2011, 17:54   #12 (permalink)
Registered User
Member: 726546
Sonork: 100.1578784
Thanks Meter: 555
update sim lock with mxkey that all urs ph will be ok 100%
Old 01-17-2011, 13:30   #13 (permalink)
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
100% new vr,4 flash br,
tejas2434042yahoo.co.in
Old 01-17-2011, 17:55   #14 (permalink)
sathvik71052's Avatar
Member: 549926
Thanks Meter: 118
Br mxkey solve u r problem....first take total rpl backup and update splock and write pm from mxkey server..100percent solve u r problem............
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.25655 seconds with 9 queries
