Old 07-04-2007, 03:10   #1 (permalink)
Member: 539327
Thumbs up Nokia 9300 No Ring
Hello -
I'm new to this forum & not a techie, but thought I may be able to get some suggestions for my phone problem.
I inherited a near-new Nokia 9300 and absolutely cannot get the thing to make any sort of ringing, beeping, etc. sounds at all. Been through the NORMAL - SILENT & VOLUME settings but no results. I can turn on keyboard clicks, but that is through earpiece. Even the Nokia intro music won't play. It takes & makes calls just fine & all else works great, but no ring can be made to happen.
My friend had reformatted the phone to remove his personal info using the CNTRL-SHIFT-F & says phone was working fine. No reason to doubt otherwise. I get it, install SIM card & no sound. I did the CNTRL-SHIFT-F & tried to install the only file on the Nokia site for reformat and kept getting this message about failed installation:
Program: sw_pclkd
reason code: KERN-EXEC
reason number: 3
I figure that there is something screwed up in the software but I haven't a clue what to do about it. This phone is in great shape & is practically new - no abuse. Anybody have any ideas what I can do (if anything) before sending it off to Nokia for a fix?
Thanks,
Dan
The Following User Says Thank You to Dan Morton For This Useful Post:
Old 07-05-2007, 09:37   #2 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
9300 no ring
Try this & see the picture
The Following 3 Users Say Thank You to chandy pok For This Useful Post:
Old 02-21-2008, 13:09   #3 (permalink)
Member: 45635
Thanks Meter: 20
i searcher and finally found it
The Following User Says Thank You to MAJESTIC PIRATE For This Useful Post:
9300 no ring ruvanw1979 Nokia Hardware & Hardware Repair 2 11-27-2007 14:24
9300 no ring ruvanw1979 Nokia Hardware & Hardware Repair 0 06-15-2007 10:38
Nokia 9300 No signal muzaffar nawaz Nokia Hardware & Hardware Repair 0 05-31-2007 06:44
Nokia 6230 No Ring, No Loudspeaker, No Backlight adeel786 Nokia Digital Core Technology 4 ( DCT-4 ) 5 06-19-2005 14:28
.: Nokia 3360 No ring no vibra :. Jani-Jan Nokia Hardware & Hardware Repair 20 03-15-2005 05:25
Page generated in 0.13464 seconds with 10 queries
