03-15-2010, 13:07 | #1 (permalink) |
Banned Join Date: Sep 2008 Location: in ur dreams
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | n 70 white light RAPx ID : 000000010000022600010006000C192101012200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 231002090A9E465176ED76EF39DCEF5E59ECC905 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00010002-00007111, Amd 29NS064J CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile |
03-15-2010, 13:08 | #2 (permalink) |
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | MCU SW : V 05wk07v48.1 28-08-07 RM-180 (c) Nokia. APE Core: APE Var : Prd.Code: 0548028 Bpr.Code: 0530940 Prod.Sn : DQF077479 HW Vers : 7004 APE HW : APE Adsp: EM RETU : 32 EM TAHVO: 53 RFIC Ver: 150a160f DSP Vers: rolf_espresso_05wk07v29p1 IMEI : 353089-02-511251-3 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland |
03-15-2010, 13:09 | #3 (permalink) |
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | UI Defaults Ok, Time: 00:02 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 |
03-15-2010, 13:13 | #5 (permalink) | |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | Quote:
yellow marked thats your problam if you already ful flashing with higher version just change combo memori 100% tested ( under retu ic the bigges ic flash ) | |
N 70 white light (Hang) | mobilecarerke | Nokia Hardware & Hardware Repair | 12 | 12-24-2008 08:56 |
n-70 white light | ataiwaris | Nokia Hardware & Hardware Repair | 6 | 12-20-2008 12:00 |
n-70 white light | ahamed imran | Nokia Base Band 5 ( BB-5 ) | 11 | 11-06-2008 10:43 |
n 70 white light only | sarassaras | Nokia Hardware & Hardware Repair | 2 | 09-14-2008 10:26 |
n 70 white light solution | mohammad shahed | Nokia Hardware & Hardware Repair | 6 | 08-30-2008 19:03 |
