08-05-2008, 17:25 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | n 72 insert sim card sir i have nokia n72 with problem insert sim card, i check and notice one leg of simtray is not show any continuty and then i replace sim ic, but after 2-3 minutes lcd shows simcard ragistration fail, i clean the boarad with good accetone, and also clean flux near the sim ic, but problem remain same, then i remove sim ic and make jumper, and handset deliverd to cutomer, it work for one some time, after one day customer again come on my shop and syas sometimes its show sim card ragistration fail,, now handset is on my shop and all points of simtray is work well, but some time lcd shows sim card ragistration faild, simtray jack is ok and not heated and not bent, board is also clean , and set is not water damage, please help me to solve this problem . thankfull to you, regards @mardeep singh sahi, |
The Following 2 Users Say Thank You to amardeepsahi For This Useful Post: |
08-05-2008, 20:00 | #2 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: bahrain
Member: 734871 Status: Offline Thanks Meter: 1,348 | Quote:
all the best. | |
08-05-2008, 20:03 | #3 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | this problem is bad conect from simcard to simcard conector 1. change again ur simcard ic (don't make jumper --- this can permanent error). 2. replace ur sim conector. 3. i agree pupaji -- try change bateray |
08-05-2008, 23:26 | #4 (permalink) |
Junior Member Join Date: Aug 2008
Member: 829616 Status: Offline Thanks Meter: 0 | n 72 insert sim card hi sir i have nokia n72 with problem insert sim card, i check and notice one leg of simtray is not show any continuty and then i replace sim ic, but after 2-3 minutes lcd shows simcard ragistration fail, i clean the boarad with good accetone, and also clean flux near the sim ic, but problem remain same, then i remove sim ic and make jumper, and handset deliverd to cutomer, it work for one some time, after one day customer again come on my shop and syas sometimes its show sim card ragistration fail,, now handset is on my shop and all points of simtray is work well, but some time lcd shows sim card ragistration faild, simtray jack is ok and not heated and not bent, board is also clean , and set is not water damage, please help me to solve this problem . thankfull to you, |
help X600 insert sim card with sim card | sofiame2006 | Samsung Hardware Repair | 2 | 05-02-2006 15:29 |
Nokia 3120 dual sim : sim card rejected or insert sim card msg??? | adrian17w | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 10-30-2005 18:25 |
3310 Insert Sim card with sim card in side | uwenk98 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-25-2003 17:28 |
Z7e insert sim card with sim card | inox | Sony | 4 | 09-14-2003 19:34 |
