Old 06-08-2009, 05:49   #1 (permalink)
SAN INFOTECH's Avatar
Member: 484665
Sonork: 100.1578012
Thanks Meter: 175
n 73 white light
i have n 73 its have only white light i trying to flash its show me this error
here is flash log is here
http://forum.gsmhosting.com/vbb/showpost.php?p=4542868&postcount=6
phone info is here
MCU SW : V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
APE Core:
APE Var :
Prd.Code: 0564012
Bpr.Code: 0563970
Prod.Sn : MCF863323
HW Vers : 8600
APE HW :
APE Adsp:
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 17211721
DSP Vers: scarfe_mc.05wk46v50p2
IMEI : 353548-02-770401-5
SL Serv : SIMLOCK SERVER VERSION 63
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
The Following User Says Thank You to SAN INFOTECH For This Useful Post:
Old 06-08-2009, 06:35   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try it.if not work agin flash..
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 06-08-2009, 14:11   #3 (permalink)
Member: 484665
Sonork: 100.1578012
Thanks Meter: 175
after remover this then i can flash ?
plz..
Old 06-08-2009, 17:50   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
plz..
Bro.set ok.. so no flash.
not ok try flash..............
Old 06-08-2009, 21:16   #5 (permalink)
Member: 1048264
Replace combo and flash the unit with the latest sofware version
The Following User Says Thank You to nanz755 For This Useful Post:
Old 06-19-2009, 11:49   #6 (permalink)
ORACHI's Avatar
Member: 918056
Sonork: 1636876
Thanks Meter: 70
any other solution with not light n73 i tray to change (coil)&(ic led drive)but still not light
[img=http://img194.imageshack.us/img194/3538/ledm.th.jpg]
Old 06-19-2009, 11:50   #7 (permalink)
ORACHI's Avatar
Member: 918056
Sonork: 1636876
Thanks Meter: 70
Old 06-21-2009, 05:15   #8 (permalink)
Member: 484665
Sonork: 100.1578012
Thanks Meter: 175
[QUOTE=ashad420;4542933]Bro.try it.if not
still same any other solution plz
sanju
Old 06-21-2009, 06:44   #9 (permalink)
mahbubalfa's Avatar
Member: 1003058
[QUOTE=THE ANT;4583084]
Originally Posted by ashad420 View Post
Bro.try it.if not
sanju
Bro.change ape ragoletor.from same set...after flash........
Old 06-30-2009, 04:22   #10 (permalink)
Member: 792874
Thanks Meter: 132
not done with solution sets camera and volume key lights on when pressing power key pls post any Goon solution neee urgent
regard,
Salu G
Old 06-30-2009, 05:08   #11 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
Bro.try it.if not
sanju
bro try it,,,,if flash is ok,,,just make jumper,,this,,step by step,,here have 3 way,,,you try one by one
::::http://www.usaupload.net/d/whnnnk35b60
:::http://www.rapidspread.com/file.jsp?id=cubr5bxidx
try and post result
Old 06-30-2009, 05:10   #12 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
brother try it and post result,,,,,
::::http://www.usaupload.net/d/8n48754lyi4
regards
gsmshare
N-73 White Screen Solution puneet14884 Nokia Hardware & Hardware Repair 128 11-04-2011 10:15
1662 white light kakey Nokia Hardware & Hardware Repair 10 03-30-2010 08:02
nokia n 73 back light problem sunil_1062 Nokia Base Band 5 ( BB-5 ) 0 09-03-2009 17:36
n 73 no light elbasri73 Nokia Hardware & Hardware Repair 3 06-08-2009 15:56
6600 white light & keypad light blink 9 times shoeb7 Nokia Hardware & Hardware Repair 5 06-13-2008 15:30
Page generated in 0.22310 seconds with 9 queries
