07-23-2005, 15:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | N-GAGE "Device start-up failed. Contact the retailer" "Device start-up failed. Contact the retailer", I was fullerase flash, MCU+PPM, write PM, unlock, format user area 10 times but not luck, any body know how to fix it? it is hardware problem, but I don't know what IC have been damaged. |
The Following User Says Thank You to pazeth™ For This Useful Post: |
07-23-2005, 19:09 | #2 (permalink) |
Member: 74519 Status: Offline Thanks Meter: 79 | "Device start-up failed. Contact the retailer" who can slove this problem? |
07-24-2005, 05:36 | #4 (permalink) | |
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
thanks for reply, I do not flash ADSP, can you tell me how to flash ADSP please? | |
07-24-2005, 09:28 | #6 (permalink) | |
Junior Member Join Date: Jul 2005 Age: 43
Member: 163925 Status: Offline Thanks Meter: 4 | Quote:
if this kind of problem happens, plug in the charger, when the phone is charging,turn it on.( this is charger start up ) once its turned on, install this file ( fixss ) to the phone's memory ( not mmc ). restart the phone problem solved. its not hardware problem ,its a firmware bug. tell me how it goes | |
The Following 3 Users Say Thank You to arisa For This Useful Post: |
07-24-2005, 11:05 | #7 (permalink) | |
Freak Poster Join Date: May 2005 Location: ksa Age: 52
Member: 149600 Status: Offline Thanks Meter: 11 | Quote:
The Following User Says Thank You to jarniel For This Useful Post: |
07-25-2005, 06:16 | #8 (permalink) | |
read my first post man, I was make format user are more than 10 times | |
07-25-2005, 06:21 | #9 (permalink) | |
07-25-2005, 07:11 | #10 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Philippnes,Pasig City
Member: 42165 Status: Offline Thanks Meter: 35 | in that case only ADSP flashing is the best solution....using JAF which is most tested for me...compare to griffin and prodigy... |
The Following User Says Thank You to Abelardz23 For This Useful Post: |
07-25-2005, 07:53 | #11 (permalink) | |
the charger start up didnt work? well , i can only help so far, just install the fixss file when you're able to boot up your phone | |
The Following User Says Thank You to arisa For This Useful Post: |
07-25-2005, 08:04 | #12 (permalink) | |
SN: xxxxxxxxx ACTIVATED BOX Phone data: V 4.03/26-11-2003/NEM-4/(c) NMP. IMEI 351520001398819 Product Profile file is: 8418099.pp Initializing Phone... Flash configuration: 9B040001007E25022540000201007E25... Boot and Flash loaders operation took 11.781001 seconds Erasing - erase took 178.547008 seconds Flashing MCU - flashing took 264.062013 seconds Flash configuration: 9B040001007E25022540000201007E25... Erasing - erase took 12.688001 seconds Flashing PPM - flashing took 20.109001 seconds Flashing DONE After flash processing... Phone data: V 4.03/26-11-2003/NEM-4/(c) NMP. IMEI 351520001398819 No Java upload specified Write Product profile file: D:\Program Files\Nokia\Phoenix\Products\NEM-4\8418099.pp Product Profile Accepted AfpOK Initializing DSP Failed to detect boot device I try to flash ADSP but giving me failed messaged | |
07-25-2005, 08:09 | #13 (permalink) | |
07-25-2005, 08:17 | #14 (permalink) |
Member: 149600 Status: Offline Thanks Meter: 11 | did the phone falldown b4 or water damage(even drops of water)? remove and change the cpu then flash it again. i solved this one time,even everything is good;flashing,write adsp,upload pm file it still appear c.s... hope it will help you |
07-25-2005, 09:54 | #15 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | [QUOTE=jarniel]did the phone falldown b4 or water damage(even drops of water)? remove and change the cpu then flash it again. cpu faulty not make that message if this problem is hardware the user area falsh ic is damaged and the way we check this is manual formate if the set not complete manaul formate so most of time as i said |
The Following User Says Thank You to Raheeeeb For This Useful Post: |
Nokia 6600 "Phone start-up failed. Contact the Retailer" | GMX@cool | WD2 & APE (Symbian Phones) | 73 | 04-24-2013 12:00 |
Nokia 6670 "Phone start-up failed. Contact the Retailer" | nathanlei888 | Twisterflasher | 10 | 04-26-2011 13:13 |
"Phone start-up failed. Contact the retailer" | CHT2000 | Griffin | 5 | 11-05-2007 16:11 |
3650 "phone start-up failed, contact the retailer" with griffin, how??? | watch man | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 03-04-2003 18:59 |
