12-09-2008, 14:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: TIMARNI(M.P) INDIA
Member: 558795 Status: Offline Sonork: 07415807668 Thanks Meter: 35 | n0kia-1208 VPP is DISABLED. Processing File: rh105_05.060 Boot... ASIC ID: 2292 DCT4 u3_2nd.fia u3_st_i.fia 849797DDE007B08D1CD63EB89EC6 Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 8828 0000 0321, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[4.31 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 013AFFFF] erasing region [013B0000 to 013EFFFF] erasing region [017C0000 to 017EFFFF] erasing region [01FC0000 to 01FEFFFF] in 73.11s Flash[2.27 MB]...in 12.91s * * Processed file in 95.02 seconds Processing File: rh1050_nai5.06mg Low level format...fail Boot... ASIC ID: 2292 DCT4 u3_2nd.fia u3_st_i.fia 84EA2BBE949662EFAF6E9EF186FB Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 8828 0000 0321, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.19 MB]... erasing region [01380000 to 013AFFFF] in 3.50s Flash[0.16 MB]...in 0.92s * * Processed file in 43.20 seconds Extract content...fail Processing File: rh105_05.06mg Boot... ASIC ID: 2292 DCT4 u3_2nd.fia u3_st_i.fia 849845DC624A7E70931F5372377A Configuration Info (9F): Number of Flashes: 2 01000000: SGS, 0020 8828 0000 0321, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[1.25 MB]... erasing region [01240000 to 0124FFFF] erasing region [01250000 to 0137FFFF] in 23.27s Flash[1.06 MB]...in 6.05s * * Processed file in 38.00 seconds * * * Phone flashing done in 4: 0 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... Phone not responding, try to set manually! 100000% salution |
12-09-2008, 17:53 | #3 (permalink) |
Member: 558795 Status: Offline Sonork: 07415807668 Thanks Meter: 35 | nokia-1208 sir, jaf box Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x2292 Reading flash chip detailes... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Error erasing area: 013F0000 - 013FFFFF////////Getting MCU ID MCU ID: 0x2292 FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.060 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 849797DDE007B08D1CD63EB89E MSID decoded: 3E4EBAE90014EDCCA9000000 FAID: 63F0CE05D2FC2D38D279E1AB Operation took 0 minutes 9 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 1 minutes 13 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 14 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.06mg Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 849845DC624A7E70931F537237 MSID decoded: 3E4EBAE90014EDCCAA000000 FAID: 5392FBE48D305AF2B68A015D Operation took 0 minutes 9 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 24 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 6 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.06mg Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: df Loader is ready... P-key nokia module version 01.02 MSID: 84EA2BBE949662EFAF6E9EF186 MSID decoded: 3E4EBAE90014EDCCA8000000 FAID: 3A6388F6919A58D96EE45CF8 Operation took 0 minutes 9 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 3 minutes 0 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! full salution sir, |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
.nes roms for s0ny mp5 and n0kia s60v2... | emoneme1619 | Nokia Multimedia | 4 | 11-18-2008 02:22 |
N0kia 1650 Dead Please Help Me | SAMESHP | Nokia Hardware & Hardware Repair | 11 | 08-31-2008 20:26 |
Application for N0kia 6630 required | dreamzvk | Nokia Multimedia | 4 | 02-01-2005 02:05 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-11-1999 10:55 |
