08-24-2002, 17:21 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: N3210 signal holds 5 sek Fiz,, did you tried for TX output ,,is it working ? willy Quote:
08-24-2002, 18:58 | #4 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | HI Fiz, NOKIA phone ,, it will show RX and system provider name in LCD , then go TX (send) phone data to register to network. in your case,, look like there is not success to register in network! you can try enable net moniter, and see at test 001 when phone start register to network, you can see it show *5 or , you can use wintesla to test on TX power level section ! you also can check at COBBA. Cobba handle for TXC (power level control) , and AFC .. many time,, no TX by cobba which is rusty in GND pin of cobba ! Willy Quote:
08-26-2002, 07:18 | #5 (permalink) |
Registered User Join Date: Feb 2002 Location: nokia Age: 48
Member: 9626 Status: Offline Thanks Meter: 0 | when i turn on "*xx",about 5 sek signal full,after that "xxx" and not signal.I suppose that you are right,there is not success to register in network.What reason? |
08-26-2002, 15:44 | #6 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | HI Fiz, not success reason ? 1: NO TX outgoing, or TX detect not work ! 2: RX out of control range for RX ,, you might check at TCXO, for GSM 900Mhz, +- 200 HZ is ok , for DCS 1800, +- 400hz it is ok,, if out of this range,, then it might have problem ! if you need, mail me, i can send you more detail Willy Quote:
Adorama 4 x 6 Post Bound Preview Proof Album with 25 Pages, Holds 5 Photos per Page, | IPMART | ipmart WebShop | 0 | 10-23-2008 08:50 |
n3210 signal always ok,but..... | fiZ | Nokia Hardware & Hardware Repair | 3 | 09-29-2002 06:59 |
N3210 signal unstable | fiZ | Nokia Hardware & Hardware Repair | 3 | 08-10-2002 07:21 |
3310,power on full signal about 5 sec then no signal!!! | xchris | Nokia Hardware & Hardware Repair | 1 | 04-15-2002 05:52 |
No signal after 5 secs. | laxxe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-16-2002 20:49 |
