05-15-2003, 07:42 | #1 (permalink) |
Insane Poster Join Date: Mar 2001 Location: Lithuania
Member: 3552 Status: Offline Thanks Meter: 0 | N3310 -> Cs Have Nokia 3310 display "CS" With rolis tool phone answer "bad MSId" ( like 000000000000100.........) Cant reflash phone , get TX high. Wintesla test show "MCU ROM Checksum- failed" Pls tell me which part need replace. Thanks |
05-15-2003, 22:25 | #4 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Guadeloupe Age: 50
Member: 9955 Status: Offline Thanks Meter: 7 | @Disaster Just full flash u're phone and it will be ok no need to change hardware or anything like this this appers when the phone have been unlocked with partial flash using DEJAN OLD method. @Zoolee change or reball COBBA when u haven't ID of it (use rollis tools 1.9) Also u will have CONTACT SERVICE. //BR |
05-16-2003, 00:09 | #5 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 43
Member: 6772 Status: Offline Thanks Meter: 17 | @ Disaster: As Allen said... the problem was descussed before... Problem is realy hardware releated! If you will stuck trhen contact me on my e-mail. Regards |
05-16-2003, 02:37 | #6 (permalink) |
Junior Member Join Date: Apr 2003 Location: CENTRAL JAVA - INDONESIA Age: 50
Member: 26504 Status: Offline Thanks Meter: 0 | Re: N3310 -> Cs For your Nokia 3310 display "CS" Problem : At rolis tool phone answer "bad MSId" ( like 000000000000100.........) Cant reflash phone , get TX high. Wintesla test show "MCU ROM Checksum- failed" I think that is sw problem... try to use virgin eeprom and rolis... Simple Solution : Check using Win DDP (Ver.4.0 or higher) and then self test... Download the software and get the fingerprint at this site.. Connected using Flasher cable and Plug the battery (power on the phone)... Klik Selft test.... If PPM Failed -> Just Re Full flash but clean the cable and board connector If Serial failed -> Change the COBBA If Pararel failed -> Change CCONT If MsID failed -> software solution with virgin eeprom Hope this will be help you... Success for all of us... Last edited by hanny_christian; 05-17-2003 at 16:59. |
05-16-2003, 22:33 | #8 (permalink) |
Member deceased !! Join Date: May 1999 Location: Wien/Austria Age: 65
Member: 5 Status: Offline Thanks Meter: 1,884 | this is not hardware-problem!!! this is only wrong unlock with partialflash! update the soft with griffin, LP2001 or other soft. you must write MCU + PPM !! than write new virgin eeprom with dejan-flasher. change imei with rolis1.9 and faid update. works 1000% |
huawei cs,zte cs, samsung cs. solution | king_naveensoni | Various CDMA/TDMA Cell Phones | 0 | 03-04-2010 08:41 |
1. Menu -> Settings -> Network Setup -> APN -> APN 3 -> Edit -> Enter 0000 -> EDIT "A | lukasartsDon | NEC | 1 | 03-28-2005 13:14 |
8210 CS --> all tests are passed | Chris02 | Nokia Hardware & Hardware Repair | 36 | 03-10-2005 17:42 |
