03-01-2002, 07:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | N3310 display problem I have following problem. I have several displays on N3310: When i power on the phone everything is OK> I can enter all "main" menus! When I enter Inbox and want to read messages there is nothing on display, just light up. i can power off the phone. When i power on it again display is working but not in SMS /Inbox menu !! where can be the problem When i change the other display , i can enter every menu in phone. i've tried also other versions of flash but the fault remains. btw , I have also one display with low contrast. Where can i find any progy for it? Not WINTESLA ) i don't like to install it . b.r. Pali |
03-01-2002, 20:24 | #6 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | hey, you just said that changing the display with another LCD works, i guess u just answered tour own question mate! just replace it and be happy! |
03-03-2002, 23:40 | #8 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | Hello to all.. yes i know that changing the display solved the problem , but it ASK ! How it is possible that when I enter SMS/Inbox the display power of ??? I clean that another LCD with low contrast and now the display have high , very high contrast. so why it happen ?? And one display which works ok, after week has the same problem ! b.r.. Pali ps; uprgrading to mcu or ppm doesn't help. |
03-05-2002, 08:38 | #9 (permalink) |
Junior Member Join Date: Mar 2002 Location: pinas Age: 49
Member: 9949 Status: Offline Thanks Meter: 0 | probably only a wintesla equipt/prommer could solve ur problem. upgrading s/w version using other equipt is of no avail to that kind of prob... better visit authorized nokia serv cntr near ur area... goodluck! |
03-05-2002, 08:45 | #10 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Hello The mostly problem for 3310 display is its lcd connector you just need to change it or clean and your problem will be cleared! good luck! Last edited by Bert; 03-05-2002 at 08:50. |
03-05-2002, 18:40 | #11 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | Hello Bert and others .. I try to clean LCD connector, and display with LOW contrast has VERY HIGH contrast. After reseting with NokiaTool using all SFS is contrast LOW again. (my display with LOW contrast has another LCD conector as the others). I'm gonna try to clean all rest displays properly and i'll let u know what's happen. Have a nice day. Pali |
03-10-2002, 00:30 | #12 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | Hello again.. I've tried to clean display contacts but without succes , the problem still remains. I think it's fault of LCD's but why it is powering of in some menus not in all !?!? For. example: I had one LCD which dissapear just in Picture MSG # 9 and #14. all other picture messages work fine. WHy ??? Pali |
03-14-2002, 22:05 | #14 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | Hello Sonya Could you be more specific with these capacitors? I will replace them but ... to replace for what? What type of another one (working ). b.r. Pali |
03-14-2002, 23:45 | #15 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | Hi, Pali. I & Sonya repaired more than 40 Nokias 3310, 8210. We try to solve this problem with many different ways and find good one - replaceing displays. Displays must be without capacitors on glass (factory made). Reset, wintesla, reflash, change PPM and MCU not help You - dissapearing appears later. If You can't buy these type of displays in Your country, I can try to help You. If You take display from other Nokia, it's not help You too. I think, what dissapearing is a factory defect (new type of plate and old type of display). PS: I don't try to remove capacitors from original display, but may be....... Last edited by Chuk; 03-14-2002 at 23:55. |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
N3310 - display lights only | husa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 18 | 10-31-2007 10:50 |
n3310 signal problem | pali | Nokia Hardware & Hardware Repair | 4 | 09-18-2006 14:14 |
3100 lcd - no display and then got display problem. | hooi76 | Nokia Hardware & Hardware Repair | 5 | 03-15-2006 17:41 |
n3310 displey problem | fiZ | Nokia Hardware & Hardware Repair | 3 | 07-09-2002 13:05 |
