03-28-2002, 05:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | N3310 ... no network (no acces) I read some posts about NO NETWORK problem. I didn't find answer for my problem . So please help me if u can . I've tried to reflow CCONT , HAGAR, PA, etc. no network on phone. When i use MANUAL SEARCH in menu, it finds just one network from 2 but can choose it. Always get NO ACCES . Any idea ? b.r. Pali |
03-29-2002, 23:24 | #4 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | @tra .. Ok, i'll try it, but no more flux now . @D-Brain I already tried to reflash with FULL FLASH from working phone. Then repairing checksums with Nk_calc, also changed IMEI to original. I'm sure it is HW fault. There was problem with PA, now it is changed and now I have this problem. ..... I have another N3310 which following problem. I was damaged by water. Cleaned. Signal full, i can make calls, receive them, I heard clean, but sometimes it is interupting me (other side hear me interupted ) I rehot it sometimes all important BGAs all was ok, and after 2 days it has the same problem (interupting ). Anyone has idea how to fix it please? Have a nice day. / Happy Easter Pali |
03-30-2002, 21:04 | #5 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Planet EARTH Age: 50
Member: 3194 Status: Offline Thanks Meter: 41 | try to replace C508 ( find it on service manual). If not working lift out c 109 above the cobba. 7 of 10 3310 solved. Note : u have to soldered c 508 perfectly , if not u will not have signal, or u kuat have single band handset. Hope help rgds |
04-02-2002, 15:25 | #7 (permalink) |
Freak Poster Join Date: Dec 2001
Member: 8214 Status: Offline Thanks Meter: 0 | try to change antena box & antena switching box. if the result is same, change the cobba and upload a full flash and change the imei calculate faid using nk_calc, use f1, f2 & f3 keys. It should work. good luck................. |
04-03-2002, 07:27 | #8 (permalink) |
Junior Member Join Date: Mar 2002 Location: pinas Age: 49
Member: 9949 Status: Offline Thanks Meter: 0 | hi rajeev, had u really tried changing cobba b4 and calc it successfully using nk_calc or it's jst a notion? coz i tried it on 33xx & 6210 and programmed using nk_calc, rolis1.5b, & dejan1.05 and when i checked the unit, what i'd seen was only the operator logo without any signal strength bar.... is there something missing with my procedure? or it's just simply can't with these softwares? neways, is there anybody here who are using dejan bomb? i heard this s/w is about changing cobba.... pls reach out.... perhaps not only me wud be happy for that.... thanks! bstrgrds |
04-04-2002, 07:55 | #9 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | Hello it's me again I've tried to rehot COBBA with enough FLUX -> no succes. Now i've removed COBBA and clean place , but this time i have problem with placing COBBA back . I'm gonna try to do it tommorow, i hope i'll have more succes. I'm using just Hot Air Gun, no BGA station. I hope if i'll have enough experiences with it , then BGA changing will be NO PROBLEM . b.r. Pali |
04-04-2002, 08:07 | #10 (permalink) |
No Life Poster Join Date: Nov 2001 Location: morocco larache Age: 51
Member: 7334 Status: Offline Sonork: 100.112291 Thanks Meter: 47 | 3310 no network me to a have the seame probleme with my nokia ,finaly i thing that the problem is in the hardware... good luck |
04-04-2002, 16:00 | #13 (permalink) |
Member: 8214 Status: Offline Thanks Meter: 0 | Hi If u can't find any network, i already mention upload a new full flash file(mcu+ppm+eeprom) and correct the imei and calculate the faid. this solution working for me. good luck |
04-04-2002, 16:17 | #14 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | @rajeev Hello my friend First of all i've tried 3 different FULL flashes and do all necessary things with NK_calc. then i try HW repair . Thanx for your reply anyway. b.r. Pali |
04-07-2002, 05:49 | #15 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | Hello to all. Problem with NO ACCES is solved. I resolder COBBA and then flash it. Now phone has full bar signal without any abnormality . But ! It is N3330 not N3310 so maybe all was ok just wrong flash (. b.r. Pali |
..::1202 no network,no buzzer,no speaker and restart::.. | HUM | Nokia Hardware & Hardware Repair | 10 | 03-16-2010 00:17 |
t20, t28, t29 no network, no access | gibso | Old Ericsson Phones & Sony Phones | 2 | 10-26-2003 12:39 |
J5 no Network no Sound????? | masterross | Sony | 2 | 08-19-2003 19:46 |
W 3000 no network.no rings HW or soft? | Kairon | LG | 0 | 07-09-2003 20:30 |
S25 no network - no service | sm@sh | Siemens Hardware Repair Area | 2 | 07-01-2002 16:14 |
