Old 07-07-2002, 02:40   #1 (permalink)
Member: 7586
Thanks Meter: 11
n3330, don't power on, power switch ok
Hello
I have 3330, can't power on, when i plug it into charger, starts charging. But i can't power it on.
power switch is ok, i change from working phone, but no results.
Any idea?
b.r.
Pali
Old 07-07-2002, 06:08   #2 (permalink)
Member: 7939
Thanks Meter: 2
Sounds silly but try full flash and see what happends
Old 07-08-2002, 10:58   #3 (permalink)
bre786's Avatar
Member: 6200
Sonork: 100.33330
Thanks Meter: 66
Hi,
I have same problem in 8890. The phone was water damaged, but it was working after cleaning. After few days it started this problem.I replaced CCONT and checked the power connections are ok. Still same problem.
wbr
bre786
Old 07-18-2002, 05:47   #4 (permalink)
Jackmaxo's Avatar
Member: 7934
Hi Pali,
The problem is that the current can't circulated in all the phone or the program is not workinng correctly. So begin by hotting the phone with hot air to avoid bad contacts and if not ok make a full flash with good one...
I am waiting for your response in my mail.
Good luck
Old 07-18-2002, 12:42   #5 (permalink)
bre786's Avatar
Member: 6200
Sonork: 100.33330
Thanks Meter: 66
Hi, Jackmaxo
Thanks for the help.
The phone can,t be flashed too, unfortunately i have returned back the phone.
br
bre786
Old 07-28-2002, 04:43   #6 (permalink)
Jackmaxo's Avatar
Member: 7934
hi friends,
No problem , to repair this begin by using service manual and follow the power circuit, go step by step to view where the current is missing...But you should work by group to resolve this quickly.
Good luck
Old 07-28-2002, 09:48   #7 (permalink)
Member: 1060
Thanks Meter: 9
Re: n3330, don't power on, power switch ok
Pali
try this:
put battery , plug your charger, and give 2.8V to battery Btemp this pin, look if phone can power up ..
if not, check PWRONX at R224 , look is it 3.7V, if not , change your ccont!
Willy
Originally posted by pali
Hello
Any idea?
b.r.
Pali
A800 no power on but charging ok Cat10 Samsung Hardware Repair 13 03-06-2005 14:58
3310 cant power on after switching off ViperGSM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-14-2004 19:34
8850 not power on, but flashing OK 100% - please help! uu1dx Nokia Hardware & Hardware Repair 1 01-09-2003 19:22
3310 powers on without switch mohammed Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-22-2002 14:52
8210 don't power on.....but charge ok Pandemonio100 Nokia Hardware & Hardware Repair 4 05-15-2002 05:13
Page generated in 0.32216 seconds with 8 queries
