N3650: No access to Memory Card Need HELP, Id format my N3650 to its original settings but when i press the menu bottons nothing happens. Pressing the other keys on the keypad a "SYSTEM ERROR" will appear. This happen when the MMC card is installed on the cellphone. I could not access just to format the MMC card. When MMC Card is removed, everything seems to be normal. Anybody has a idea with this problem, short cut keys to access memory card. :( Desperate.. |
1:N401 2:R472 3:UPP that it ! |
maybe the mmc card is already defected or damaged, try another mmc card to your phone, if is it ok, then your mmc card is defective. |
Maybe you have backup the phone system to MMC,... and when you upgrade your phone firmware... thats the time you will experience phone problem if the MMC is in your phone. You should reformat your MMC using another phone or hardware like card reader/writer. |
Thanks. My problem was solved, id reformatted my MMC with another cellphone. Mmc went ok except for deleted files, i've reloaded my programs into my N3650 ;) |
reformat mmc card 100% work, i had this problem before ,jusy format mmc card withn usb card reader everything is ok:) |
