08-12-2002, 21:24 | #2 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | hello fiz, 1 change antenna 2 resoldering or change the duplexor filter(swich antena). old alcatel(one touch easy) have same piece. geo |
08-13-2002, 22:47 | #5 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Fiz, did you check X540 (for ext antenna ) ? check it in /out is short or not ! Willy Quote:
08-14-2002, 15:29 | #9 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Re: to willy Fiz first, you try connect EXT antenna to test your phone! if you do not connect ext. antenna , then it X540 must be short Willy Quote:
08-15-2002, 12:07 | #11 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Re: hmmm........ Rauvenz, X540 in/out must be short when you do not use ext antenna! then you can check AFC at 13Mhz TCXO control by cobba. to see how is TX frequence range good or not ! then send 947.06771Mhz at -55dbm to antenna connector, then start to check 13M and 71M filter one by one for 67K (67.771K) Willy Quote:
LG KG800 chocolate no signal or low signal | ProGsm2K7 | LG Hardware Repair | 3 | 09-26-2009 12:38 |
N5110 no signal | erwan | Nokia Hardware & Hardware Repair | 1 | 04-29-2003 10:17 |
Nokia 3210 Low signal (cobba is OK!) | D-Brain | Nokia Hardware & Hardware Repair | 2 | 01-29-2002 09:27 |
A1018 no very low signal | Fludor | Sony Ericsson Hardware Repair | 3 | 08-08-2001 00:30 |
Siemens C35 Low Signal | Crash2 | x1x to x45/x50 | 1 | 08-07-2001 16:32 |
