Old 08-11-2008, 10:18   #1 (permalink)
5mobile's Avatar
Member: 70278
Thanks Meter: 19
N70 auto charging n led light off
hello,for all expert l have n70 when charging set become auto charging n the led light off ,n the phone also auto off,wat is the solution pls!!!!!
The Following 2 Users Say Thank You to 5mobile For This Useful Post:
Old 08-11-2008, 10:53   #2 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
check the charging interface first then change thahvo.
all the best.
Old 08-11-2008, 11:07   #3 (permalink)
Member: 772386
Thanks Meter: 157
i cant
understand plz can u give me the picture plz plz
Old 08-11-2008, 15:40   #4 (permalink)
Member: 223257
Thanks Meter: 12
Chang TAHVO IC working 100%
Old 08-12-2008, 11:06   #5 (permalink)
5mobile's Avatar
Member: 70278
Thanks Meter: 19
hello, l have change the tahvo i/c but still the same prob,pls help me !!!!!
The Following User Says Thank You to 5mobile For This Useful Post:
Old 08-12-2008, 12:16   #6 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
please cek C vbat link to tahvo ic.
Old 09-15-2008, 09:52   #7 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
Old 09-15-2008, 10:17   #8 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
chang the retu ic u r two 100% solved. or re boll.
Old 09-15-2008, 10:31   #9 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Smile
here is your solution i hope solved your problem post result soon......
BR.
IKRAM BUTT
The Following 4 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 09-15-2008, 10:35   #10 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
thanks good job ............
The Following User Says Thank You to Rizwan ch08 For This Useful Post:
Old 09-15-2008, 10:38   #11 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
change retu solved ur problem,,,,,,,
Old 09-15-2008, 10:52   #12 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
its rap3 not tavho am very sure dont waste ur time
Old 11-04-2008, 21:31   #13 (permalink)
Member: 39245
Thanks Meter: 43
Have same problem ....
Retu & tahvo have changed but problem still remained
Will try to change RAP & post the result...
BR,
Old 11-05-2008, 08:24   #14 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
BR.
IKRAM BUTT
This is not n70 solution this is n73 here is solution for n70 & n72 bettery not save & auto charge.
Old 11-05-2008, 08:37   #15 (permalink)
ameerali19's Avatar
Member: 884639
Sonork: 100.1597105
Thanks Meter: 266
is it n70 or n73???
if n70 , check charging path, tahvo & retu
check is there any short or leakage in board
N70 Auto Charging & Auto off Rahuman28 Nokia Hardware & Hardware Repair 0 12-10-2009 13:28
N70 auto charging plz help with daiagram asif_ae Nokia Hardware & Hardware Repair 0 04-11-2009 15:29
n70 auto charging ADNAN440-BANNU Nokia Hardware & Hardware Repair 2 04-04-2009 06:51
N70 auto charging problem satheeshkannank Nokia Hardware & Hardware Repair 9 02-18-2009 16:16
E398 led light off problem solution actionmobile Motorola Hardware Repair 0 08-27-2008 16:27
Page generated in 0.29602 seconds with 11 queries
