Old 05-27-2007, 08:50   #1 (permalink)
Member: 12724
Thanks Meter: 30
6270 upper keypad
6270 upper keypad problem.
flex cable is OK
EMIF is OK
1.8 volt on keys present
is it RAP?any soultion
Old 05-27-2007, 08:55   #2 (permalink)
Member: 350571
Thanks Meter: 920
flex cable is OK
EMIF is OK
CHANGE STRIP CONEECTING WITH DISPLAY AND PCB
YOUR PROBLEM SOLVE 100%
Old 05-27-2007, 08:57   #3 (permalink)
Member: 201126
download its manual friend
Old 05-27-2007, 09:10   #4 (permalink)
Member: 363878
Thanks Meter: 61
i have also problem. with back light problem.
and i can solve it . by find out broken line.
please check line on board compare with another boad.
i think some line is broken. become perharp some water or moistuer.
can to in by front key board this phone is easier. Good luck.
Old 05-27-2007, 09:17   #5 (permalink)
Member: 12724
Thanks Meter: 30
CAN YOU READ?????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????
this strip's name is FLEX CABLE and If you can read,you can see this "flex cable is OK"
pls read whole post befor reply
I post this BOLD FONT for ppl like you that dont read posts befor answering,but BOLDING fonts was useless too!!!!!
Problem solved,it was RAPGSM thanks for replies
Old 05-27-2007, 15:37   #6 (permalink)
Member: 354903
Thanks Meter: 10
pleas change keypad ic near to display conector right side ic is use to display and some keypad so just rehut or reboll ic the best solution or change it ok see u replay soon ???????
Old 05-27-2007, 16:15   #7 (permalink)
Member: 12724
Thanks Meter: 30
Thank you BUT:
Why yo dont read posts before replying?
At first post I said EMIF is OK(EMIF means drive Ic-then I chaecked this IC before post)
Ay my secon post I told PROBLEM SOLVED and it was RAPGSM problem.
The Following User Says Thank You to .::AkhavanGSM::. For This Useful Post:
6270 upper keypad problem .:SARCAR:. Nokia Hardware & Hardware Repair 8 10-15-2008 11:18
6270 upper left button wont work tolgatt Nokia Hardware & Hardware Repair 3 01-23-2008 04:44
6270 upper board display missed lines !!! mobilagy Nokia Hardware & Hardware Repair 3 12-27-2007 08:57
6270 upper keypad not working relish Nokia Hardware & Hardware Repair 0 11-07-2006 10:20
Page generated in 0.17941 seconds with 9 queries
