Old 07-21-2008, 10:24   #1 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
N70 Charge ok but power switch is not working
Hello brothers.
I get N70 with White LCD, charge ok. when i connect the charger phone's white lcd bcome but can't on/off with power switch.
LCD is ok crystal ics r ok and lcd jack was water damaged.
any body have its solution then plz share thanx in advance.
Old 07-21-2008, 11:41   #2 (permalink)
hitesh2000's Avatar
Member: 365730
Thanks Meter: 84
try the power switch jumper from near retu to poer switch
Old 07-21-2008, 12:52   #3 (permalink)
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
Power switch circute is fine bro
any one have another solution
thanx for reply bro
Old 07-21-2008, 13:38   #4 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
use this pics
Old 07-21-2008, 15:57   #5 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
Originally Posted by Adil Mobiles View Post
Hello brothers.
simple...change lcd ic's.bcz on-off line coming from lcd ic(right).post result.i hope 100% will fine.
The Following User Says Thank You to pupaji For This Useful Post:
Old 07-21-2008, 15:58   #6 (permalink)
Member: 819138
Thanks Meter: 3
thanks 4 this good sharing.
Old 07-21-2008, 16:15   #7 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
n70 white display
try this and post result
Old 07-23-2008, 17:06   #8 (permalink)
roy_naber's Avatar
Member: 395897
Thanks Meter: 56
change the right screen ic it will work.. tested%
Old 07-23-2008, 17:23   #9 (permalink)
.:KRISHNA:..:MOBILE:.'s Avatar
Member: 304012
Thanks Meter: 322
The Following User Says Thank You to .:KRISHNA:..:MOBILE:. For This Useful Post:
Old 07-25-2008, 12:57   #10 (permalink)
archon2807's Avatar
Member: 772714
Thanks Meter: 23
hav a gud job bro, i got a tip hir? this site i proud cuz i'm new for repairing and i got a lotz of trikz...!!!! lot of thnks all...!!!
Old 07-27-2008, 20:26   #11 (permalink)
Member: 819138
Thanks Meter: 3
pupaji your right.thanks.
Old 07-27-2008, 20:34   #12 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
good work guys .......
Old 07-27-2008, 21:18   #13 (permalink)
Member: 675717
Thanks Meter: 125
Thumbs down
Hello brothers.
N70 have 2 display ic (25 pins).Just change right ic.Post next condition.
Old 07-27-2008, 21:24   #14 (permalink)
power1977's Avatar
Member: 134158
Thanks Meter: 30
Hello brothers.
already posted here... http://forum.gsmhosting.com/vbb/show...&postcount=148
Old 07-28-2008, 05:40   #15 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
Hello brothers.
bro,
remove 2 capasitor as show in picture and then make jumper as show in picture
100% solved your problem
no need to change display ic
post your result
The Following User Says Thank You to jimm07ct For This Useful Post:
nokia n70 chargeing ok but no power on san9090 Nokia Base Band 5 ( BB-5 ) 10 05-21-2011 09:50
lg 270 charging ok , but power not on kashif_khatri LG Hardware Repair 0 11-27-2009 15:22
n 70 charge ok but dosn't switch on nilkamal Nokia Hardware & Hardware Repair 4 06-22-2008 11:19
N1100, Charge ok but can't switch on haider Nokia Digital Core Technology 4 ( DCT-4 ) 15 02-01-2006 07:44
N1100 charge ok but can't switch on haider Nokia Hardware & Hardware Repair 5 10-10-2004 14:14
Page generated in 0.30238 seconds with 11 queries
