12-12-2006, 19:45 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 374225 Status: Offline Thanks Meter: 41 | n70 charging but batt not charge |
01-30-2007, 09:06 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Philippines - Saudi Arabia
Member: 396326 Status: Offline Thanks Meter: 229 | U can open the file with intertet explorer.... The small glass ic is diode and the other fuse.... u can replace the glass diode with ordinary diode came from 3100,6610 or same... scratch the board to make it contact at the ground.. But maybe still same problem eventhough u change that's component still no charging at the battery...I'm still researching for that solution. If u repair that problem pls.. post the result or email me... br capri |
01-31-2007, 17:50 | #8 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Minsk Russia
Member: 5569 Status: Offline Thanks Meter: 10 | i seen this pb. i try to test before by put charge in without batt. and check volt out at batt tip volt out still = >3.7 if not = < 3.6 volt it cant charge i will reball or change Tahvo all work [if not have any volt then check volt before Tahvo to fuse] |
2310 when charging only battery simbol appear,but mobile not charging please help | shivam4you | Nokia Hardware & Hardware Repair | 5 | 01-03-2009 10:43 |
k508 charging but realy not charging | telefan21 | Sony Ericsson Hardware Repair | 2 | 12-28-2008 11:27 |
z510 showing charging but bettery not charging. | MUTUAL | Samsung Hardware Repair | 1 | 07-12-2007 03:07 |
u8330 charging show but battery not charged | parveen kumar | LG | 6 | 01-12-2006 07:29 |
talkabout charging but infact not charging | CellM@n | Hardware Repair by brands | 4 | 11-21-2002 21:29 |
